Must-have tools for the homeowner.
vartz04
LaSalle County IL
I have just about all I need to do what I have the ability to do for mechanics tools. But today I was thinking I don't have a damn thing when It comes to homeowners tools aside from a few things. What are the must haves in your guys opinions. All I have now is
Full set of mechanics tools
4' Level
2' Level
20 oz Hammer
16 oz hammer
Ryobi One+ Drill, Impact Driver, Circular Saw, Recip Saw, Flash Light, and Weed Wacker
Thats about it. Ive got a $1000 garage upgrade budget but I realize I am going to have to use most of that on house tools and such.
jeffmoss26
Cleveland, Ohio
Re: Must have tools for the homeowner.
Do you have all of the various tools for plumbing and electrical already? I am sure there will be a fair amount of crossover with what you already have (pliers, wrenches, screwdrivers etc)
franzdom
NC
Vise
Stud finder
Lawn mower
V
vartz04
LaSalle County IL
Got the lawnmower running last night, need a vise, and a stud finder. I have the wrenches/screw drivers/wire strippers ect already. I will need some pipe wrenches for the plumbing work. Another thing I just thought of is a speed square
jeffmoss26
Cleveland, Ohio
Buy a bunch of tape measures and utility knives and put them in various places so you always have them!
TDLMOMOWERS
Basin wrench. Multimeter. Test Light. Framing Square. Combination Square. Tubing Cutter. Saw horses. Chain saw.
chrisexv6
CT
Shop vac
(Im partial to the ones with the pump built in just in case you are sucking up water and dont want to lug it up to a sink)
signcrafter
This! Can never have enough of either of them.
House tools can add up very quick depending on what you are wanting to do. Start with carpenter tools, hammers, tape measurers, speed square, 12" square, knife, nail punches, chisels, hand saws. Then add things like drywall tools, 6", 10", 12" knifes, metal mud pan, mixing paddle, good stapler, keyhole saw, drywall sanders, texture sprayer. Then add electrical tools, wire strippers, linesmans, diagonals, screwdrivers, torpedo level, GFCI outlet tester, non contact voltage tester, auger and spade drill bits, hacksaw, telephone cable tools, coax cable tools-stripper and crimper. Plumbing tools, pipe wrenches, soldering stuff-(torch, solder, pipe cutter, inside and outside brushes, flux), garbage disposal wrench, channel locks, crescent wrenches, PEX crimpers. Painting supplies, brushes, rollers, handles, trim brushes/rollers, pans. Flooring tools, tile tools, laminate tools, carpet tools.
Power tools, a decent miter saw is probably one of the most versatile power tools next to a cordless drill. A table saw is also nice to have. A nice big low RPM drill is nice for mixing drywall mud and many other things including drilling larger holes. A hammer drill for drilling concrete, if you can afford one that you can switch to hammer only so it won't rotate so you can use the hammer drill as a chisel. Air nailers are also very nice if you are doing trim.
A good supply of nails, screws, bolts, etc are a must. Over the years I have accumulated a large stock of hardware and it's great not having to run to the hardware store everytime I need a certain screw or nail. Also things like electrical boxes, outlets, switches, wire, wire nuts, staples. Some plumbing supplies for emergency repairs like, fernco couplings, some valves, copper fittings, PVC fittings, a few sticks of PVC and copper pipe.
The list can go on forever and will grow each time you need to do a repair or a new project. The problem is depending on how DIY you want to be the more tools you need. Also unlike working on cars where wrenches and sockets are your main tools and then some specialty tools, home tools are a lot of "specialty" tools with very few being used for more than one thing.
Personally I believe in doing almost all repairs myself. My theory is if I can buy tools and supplies to do a project for around the same price as hiring someone than I will do it myself. Then next time I will already have the tools needed. I bought a tile saw for 700 bucks a few years back, it has paid for itself many times over now.
If you are very DIY and do everything yourself then you will NEED many tools. If you just want to pound a few nails here and there then you really don't need much.
V
vartz04
LaSalle County IL
Yeah almost everything will be DIY. That is a good list you made there. I don't need everything at once but ill be grabbing a big chunk of it soon.
HandyManny
Out West
Of all the things in a home that will wear out and need fixing or replacing the most I'd say learn the basics of plumbing.
10" adjustable wrench
8" adjustable wrench
10" Channellock #430 tongue and groove pliers
Set of screwdrivers
good flashlight ot headlamp
work light
pipe/tube cutter
hacksaw and assortment of blades
bench vise
tape measure
assembley of various washers
hammers (claw and ball pien)
pry bars
cold chisle
long nose pliers (7")
Linemans pliers (7.5" are good for the average joe)
safety goggles
Good home repair book
sturdy work bench and suitable work area
putty
pipe dope
teflon tape
duct tape
vise-grips
Level
saw horses
willhollin
Worcestershire, England
signcrafter
If you are going to be making a large purchase of DIY home tools I would go walk up and down the aisles at HD, Lowes, or Menards and spend a few hours looking at tools. Look at the tool section and also in each department. Look at each tool and think if you could use it and what for. Make a list. Ask questions here about tools you aren't sure of or where you would use them.
What projects do you have coming up? I like to think of what tools I will be needing, do research to find out what the best brand of tools is the best quality and price.
V
vartz04
LaSalle County IL
First things we are going to do to the house are
Paint
Clean Carpets
Replace Bath Tub
Those will all happen within the first week minus the tub that will be sometime in the first month. The tub itself is fine it just doesn't look nice in the totally remodeled bathroom. I know why they didnt take it out (old iron tub) so I might just try a tub refinishing kit on it for now like the one rustoleum sells. There have been quite a few good reviews on that.
Within the first year of living there we plan to
Replace kitchen cabinets/countertops with premade ones from a big box store (kitchen layout ***** lots of space but they didn't use it right)
At least frame/hang drywall in basement
Trick out the garage.
So i need the paint, the electric and the plumbing stuff first. My dad has a ton of stuff I can borrow but thats a pain driving to his house to get the stuff. If its something expensive and won't be used often though I will borrow it.
What I did with my mechanics tools is bought craftsman for sockets/wrenches/ratchets, and harbor freight/chinese junk for the rest. If I find myself using it a lot or the cheapo breaks I go buy a good one. That might seem like spending a lot of extra money buying stuff twice but most of the stuff I haven't touched since I bought it for its initial use and the few things that did break and got replaced haven't equaled out what I would of spent on high end stuff if I bought it in the first place. I will probably go this route with some of the house tools too. Obviously not going to buy a harbor freight circular saw but lesser used stuff ill give the cheapo a shot.
RedFordTruck
Id invest in a power sander.
Ive got a corded dewalt Orbital sander and a 18v Porter cable Triangle shaped sander that I find myself using a lot. I prefer the Dewalt when running an extension cord isnt a problem, but I recently did some sanding and painting up on a ladder and I found the Cordless sander to be invaluable.
stratman977
Belle Vernon, PA
In all seriousness you can spend a fortune on tools now and not have any money to do the projects or you can buy things as you need them. I would have a few things on hand like the pipe wrench, electrical tape, screws,nails and the like. Buy the miter saw when you need to do framing work, buy the tile saw when you want to put in a new floor. Costs for getting a new home add up quick. I'm all for buying tools but don't tie up a bunch of cash in stuff that you don't need right away.
There will always be something unexpected like the water heater bursts, the fridge quits, furnace quits that you need money for which you don't have cause you spent everything getting the home. I still got some credit card debt from getting my home cause the unplanned expenses in the first few months killed me.
joshmodelskidoo
mid western michigan
if u get drywall tools i would recomend stainless. i have some regular and some stainless and the regular stuff has some rust from water in the mud and cleaning. i let the stuff air dry so maybe thats the reason. plastic pans with the medal edge get mud build up and rust and the edge comes out after a few uses. i have a cheap brad nailer from menards and that thing is great, and there like $20 and well worth it. hit some yard/garage/estate sales and pick up the stuff there. old screwdrivers work pretty good for prybars also. i have a miniture prybar i use on trim and its cheap
RKA
signcrafter pretty much summed up everything I was thinking. I was in the same boat once, and in all honesty, I quickly learned that car tools only go so far in the house. The house tools have dwarfed the car tools by now. I'd focus on the projects you want to work on, and buy the tools for those projects. Soon enough you'll have everything handy, but for now, lots of trips to the big box stores.
I'm with you though...often costs a bundle to call someone in, and even when buying expensive tools they often pay for themselves by the first or second use. It hurts having that attitude the first 2 years or so, but now I feel like I'm over the hump and when I need something I go to the basement or garage and it's there.
*edit*
One thing I would do though...is keep that list (and reserve fund) handy and look for good deals. I've saved well over 50% on stuff I didn't need right then and there for a project, but I caught a good deal online. But only do this if you're paying cash and it's not taking away from other projects, otherwise it devalues that "good deal". Black Friday to Xmas is nuts! Enjoy the house!
chrisexv6
CT
Paint - get a SherLock (by Wooster) extendable pole for roller use. They dont use cheap cam locks that always give in eventually, its a push-pin type lock that holds tight no matter what. I have a 4-8' but they also make 2-4 and I think 8-12 if you need it. Lots of drywall tools because you'll inevitably want to make the walls nice and smooth before repainting (dings/dents/chunks in drywall bother the heck outta me). At least 4, 6, and 12" knives. Look for the Dust Control compound, it helps at least a little with airborne dust. Get one of those drywall sanders that screw on the end of a pole (you can use the SherLock there too if you want, I choose not to), and drywall sanding *screens*, not sandpaper. They hold up a lot better IME.
Clean carpets - seriously, see if you can get one of those $99.99 Stanley Steamer whole house or at least one floor deals. I like DIY-ing everything too, but Ive yet to find any machine that comes close to cleaning carpets like they can. Heck its 30.00 just to rent a Rug Doctor for a day and the results are no where near what the pros can do in a lot less time.
Replace bathtub - if existing is cast iron, get a cheapo moving blanket (Job Lot, Odd Lot, etc will have junky ones for one-time-use) and an 8 lb sledge. Cover the tub with the blanket and swing away with the sledge. Careful with the shattered pieces but its the easiest way to get a cast iron tub out.
bassbone52
Central Indiana
I'm all for having a lot of tools, but unless you have a lot of threaded pipe to replace, I wouldn't wrap up too much dough in pipe wrenches. Sink and lavatory traps usually just require a some channelocks and most water lines are copper or some kind of plastic. A good torch plus some flux and solder would be something you might consider. Also a good hacksaw.
GirlnAgarage
Texas
I agree with this line of thinking.
When we rented we had the basic hand mech/home tools but after we moved into the house we purchased tools as the project/need comes up. Immediately after moving in we bought the lawn tools - mower, weedeater, shovel. From then on it's been as needed. So I keep thinking up projects so I keep needing tools :D
Overall:
- electrical tool box
- plumbing tool box
- paint bucket tools
- wood work tools
- mechanics tools
- yard tools, including axe/firewood stuff
- grilling tools
Have fun getting everything together. It as taken us three years to get to this point where I feel pretty prepared to tackle anything around here. So far, I have done a bit of everything. Before you know it you'll have a good selection to tackle anything that comes up with the exception of running to the store for consumables, materials and parts.
Hiball
Missery
+1, pencil's too.
+1 Awesome.. I was doing some work the other day and my Wife walked upstairs and had the Strangest look on her face.. I asked her was wrong and she pulled 3 carpenter pencils out from between my Hat/Head.
signcrafter
Paint
I will share this tip with you that took me many many gallons of paint to figure out. Go to a real paint store, sherwin williams, benjimen more, etc. Their paint is a lot better and they have people working that actually know a thing or two about paint unlike the big box stores. Sherwin williams has a preffered customer program you can sign up for online and get 30% off almost once a month. Buy good brushes and wash them good. I used to by cheap brushes and throw them away but it's worth the time to wash them right. Same with quality rollers. Drop cloths, pans and liners, trim cup, lots of good masking tape. Painting is one of those things where spending the extra couple bucks goes a long way, trust me.
Clean Carpets
This is one of the things I would at least look into hiring out. Only because I can't buy a good quality cleaner for anywhere near what I can pay someone to do it for. Even if I cleaned the carpets every 6 months it would take ten years to pay for a good cleaning machine.
Replace Bath Tub
This is going to be your can of worms. Replacing a tub is going to need a ton of all sorts of tools. You will need a tub drain wrench, sledge hammer and five gallon pails to carry the tub out. All sorts of plumbing tools. Assuming you have copper pipe you will need the tools I listed above for sweating pipes. Also need tools for working with PVC drain pipes. You will probably need drywall tools to repair around the tub/surround. You will need a caulk gun. The list will get very long real quick after you open things up and see exactly what you are working with.
Here is another one that can need a bunch of tools depending on some things. In my experience a simple job of ripping out some cabinets and putting in new ones always turns into a bigger job. Things are out of level and out of square. Cabinet installs are pretty easy but if things aren't level you will have to deal with that. If you go with laminate tops you will need a belt sander to scribe to the wall cause the walls aren't "flat".
Saws, hammers, nail guns, hammer drill or 22 nail gun, framing square, levels of all sizes, chalk line. Stapler for insulation. If you are going to drywall you will need to do electrical first so will need all tools to run wires like drill bits and a strong drill along with electrical hand tools. Drywalling, buy a screwgun and a rotozip. While neither are needed they will make the job go easy. The gun takes a little getting used to but it sets the screws to the right depth everytime. The rotozip lets you hang a sheet of drywall without having to measure outlets, hang the sheet losely and the rotozip will trace the outlet and make a perfect cut.
If your dad has a ton of stuff he should have some experience and be able to take a look at things and give you a rough idea of exactly what you need.
Answers in red.
V
vartz04
LaSalle County IL
Thanks for all of the tips.
I really don't have the desire to dive into the bathtub replacement just yet. The rest of the bathroom looks perfect and was just redone the tub just brings it down. I read a lot of good reviews on the DIY bathtub/tile refinishing kits and they are cheap so I am going to give it a shot.
I forgot to write that I planned on having someone come clean the carpets. My parents have a carpet cleaner I can use but it doesn't do as good of a job as the pros.
plinker
Northern Wi
Something else to add if it has not been mentioned already is a 4' drywall square or "T" square. They are very handy to have for using as a straight edge and for accurately marking plywood and drywall & other sheet material for cutting.
Shouldnt be more then 10-15$.
Toymeister
North Florida
Other than the tools to do the jobs the OP mentioned, I would chase the skills that will you will need the most balanced by the dollars saved with a bit of frequency that you will need them blended in.
Please let me explain. In a home you will need electrical and plumbing skills. Things need to be replaced and you save big bucks. Basic house wiring doesn't require many tools except for a proximity current detector (4.99 at HF) the OP probably has most of the tools. For plumbing it will depend on the type of pipes in the house. PEX tools are much different than iron pipe tools. Drywall tools are also a great idea.
For the shop and mechanics tools I would invest in auto repair specifically brake repair tools and strut compressor. Brakes and stuts self repairs will save you lots of coin
nucklebuster
Fargo ND
I'd strongly suggest looking into what you can rent in your area. Having worked in a rental shop for a bit, it's far more cost effective to rent than buy if you aren't looking to put many hours on a tool. Drywall equipment can add up fast, as well as other "speciality" tools. Not sure how deep you're planning to dive into any one project, but may very well be worth a gander... best of luck!
HandyManny
Out West
In addition to your plumbing tools I forgot to say lawn and garden tools. Also tools for maintaining your lawn mower and other powered lawn equipment (your automotive tools should have a selection that covers that).
One thing I will say to the average home owner: Absolutley forget about buying a pipe wrench! For some odd reason that's the first plumbing tool that everyone goes out and buys. I don't know why! Most likely (unless you will work with iron pipe or gas lines) you will never have any real need for a pipe wrench. Instead, use that money to buy an offset hex wrench like the one Ridgid makes or some type of larger capacity tongue and groove pliers, these will come in handy for drain slip-nuts and toilet tank slip nuts. Meaning, large fasteners that don't require over-tightening but do require large capacity tools for securing.
rodm1
That seems to be what I use the most. Then skill saw, drill, and a sawzall seems to come in handy.
camarotoolman
cocoa Fl.
Shovel, rake, rake, weed wacker, axe, prunning saw, wheel barrow. Paint brushes, roller tray, rollers, drop clothes, tube cutter for plumbing, torch to solder pipes, speed square, cordless drill and bits, ceramic saw ( cheap used one) puddy knife, dry wall tools, pry bars, later screw gun for dry wall, pressure washer for exterior of house, grinder to sharpen mower blades. I think we went there this topic a few month ago. I wouldn't buy alot of stuff till you need it unless you live many miles from the store, also you can get alot of good tools cheap at yard sales etc.
