ranger_dood
To start off, this is a house question, not a garage question, so I apologize.
Background - 95* outside and climbing, I have one large 110v window AC unit running downstairs, and one small 110v unit upstairs. Home from work today, so I'm doing laundry, which means the washer and electric dryer are going. I have no doubts that my fridge and freezer (two upright units) are probably running quite a bit to keep my snacks and beer cold. Add in some various smaller loads... two PCs, an LCD TV... whatever you like.
Panel is a GE... was installed when they converted over from the original fuse panel. Main (and service) is 100A, which I've been concerned about in the past. Mostly just due to age, and I'm more "used" to seeing 200a service (and indeed, that's what was on the listing when I bought the house. oops..._).
I went down to check the main today, because I've been considering upgrading the service, or at least replacing the panel with something that has easier-to-find breakers. Using my IR gun, I found that the top pole on the main was at 162*F, and the bottom pole read 186*F, as measure on the side of the casing with the front off the panel.
Took my clamp ammeter, and read one leg at 13.3A, and the other at 16~A. To me, this doesn't seem right... because I measured just a single hot leg going out to the dryer, and got a reading of 23A on that leg alone.
So a few questions- Is it normal for a main to get that hot, and still not trip? Am I approaching the limits of my 100A service? Is the main just old, and needs to be replaced? Why am I seeing such low amperage on the main legs, when other lines are showing higher? Can someone please turn the heat down?
Oh, and - Can you change out a panel, without pulling the meter? Should I even consider asking an electrician to attempt this, or will they just laugh at me? Is it worth replacing the panel with another 100A, or take that opportunity to do a full service upgrade? The pole with the transformer is right outside my front door, and actually on the corner of my property.
Thanks for any advice or musings you might be able to give. I'd rather not burn the house down just because I need clean (and dry) shorts.
