9mm? What do do with a 9mm?
spencerian
Columbus, Ohio
Socket that is.
What use is a 9mm? I can't think of a single time I have used my 9mm socket or wrench.
That being said, if you buy Snap On tools the set price is the same as buying pieces. So you could save $10 on a metric shallow socket set by buying them seperate and omitting the 9mm....right?
Moose-LandTran
The Brink of Insanity (England)
I actually asked my friend this recently. Because i couldn't recall any use for either 9mm or 11mm sockets/wrenches. He reminded me about them being used frequently on European brakes. I then spent two days doing god knows how many brake lines on two cars, constantly using my 11mm flare-nut wrench.
eschoendorff
Not the 9mm I was thinking of...
speed bump
Butte Montana
I needed a 9mm the other day for a bleeder valve on a Honda Nighthawk 750. At that point I didn't have one but now I have 2.
BTW I need a 9mm socket in my 3/8" drive set hopefully i'll find one soon.
billymade
New Mexico
Moose, do you actually run across anything that has "british" or "standard" sizes anymore, from some shows I see on BBC America certain US car brands like Jeep seem pretty popular over in your side of the pond. Also, someone told me about a early "british" size of fasteners that is something totally different then regular "standard" sizes as well; they say they were used in the 50s and earlier! Does this ring a bell? Maybe old Brit bikes and cars?
JeepsAreBuilt
The Beautiful NorthWest
I use the 9mm at work sometimes.. very common for ford bolt in windows to have a 9mm nut. I'm glad I have a 9mm ratcheting wrench too.. cuz those 9mm nuts are tucked up behind the headliner sometimes. Anyone else get annoyed when ford uses sae and metric head fastener sizes ?
Moose-LandTran
Britist Standard is more common among plumbing and pipework. As far as i know it never made it to the automotive industry. I do belive it was used in industry and was used on steam engines.
The other sizes you're thinking of may be Whitworth. These were not so common, although were used on some old cars. Whitworth sizing is different in that instead of using the size of the hex, it uses the size of the thread. So a 1/2" whitworth bolt means the thread is 1/2" and the hex is a different size.
As far as i know, the only use for Whitworh nowadays is in scaffolding. Scaffolding nuts and bolts use 7/16 Whitworth.
use it in place of a 3/8s
3/8" is manufactured closer to 10mm, with tolerances. 3/8" is a "true" 9.5mm but in production this is closer to 10mm
heelsroll
On a rock in CT
Billymade, are you thinking of Whitworth fasteners? 55 degree angle thread, and wrenches/sockets marked with the size of the bolt, not the bolt head.
Also, my American GMC uses almost exclusively metric fasteners!
(My '70 Scout is all SAE, all the way....)
Best,
J
700jfm
It seems like my son and I would use them when he ran motorcorss. :headscrat on what I can't remember. But if I didn't have one I would feel like I was missing something. or my set was not complete.
bigjon
NSW Australia
Are you thinking of 'Whitworth'?
Fedwrench
Valley of the sun
Stick it on that hanson peg along with the 20mm to catch a little dust. I think the Ford trim bolt was actually an 11/32 but, 9mm works. I wish Craftsman would trade that 9mm into an 8mm on their 3/8 drive deep 6 point socket sets.
billymade
New Mexico
I couldn't remember the name but some old timers were telling me about them; maybe old bikes like BSA, Triumph or Matchless had stuff like that? I think I heard about them in relation to talking to ********* old British bike aficionados!
OctaneMotorsports
Caledonia, Ontario, Canada.
9mm deep for the emulsion/atomizer tubes on some two-cycle racing carburetors. Allen and Snap-On are the only two I know of that work, most people have the Snap-On for this job. I haven't tried my SK yet.
Bicycle derailleurs have 9mm bolts on the cable clamp sometimes, too.
Merkava_4
Clovis, CA.
The bleeder screws on my Buick LeSabre take a 11mm wrench believe it or not; but now I got me a homely black oxide wrench for that duty. :D
MAD
Western MA
To do a clutch on a A2 (85-92) VW Golf/Jetta you would need both 11mm and 9 mm. The bolt that retains the speedometer cable has an 11mm head. The pressure plate bolts have 9mm 12 point heads. I believe there is either a 9mm or 11mm for one of the bolts on the clutch cover plate tin as well.
Aftermarket nuts for headers on air cooled VWs are often 11mm across flats as well.
like these:
http://www.vwparts.net/mm5/merchant.mvc?Screen=PROD&Product_Code=BP2505-20&Category_Code=ZProdList
Fedwrench
Valley of the sun
I have both shallow and deep 20mm socket, and don't recall ever using either of them. Apparently, they do get used though.
I've always wondered who uses them. there are uses here for a 20mm wrench (GM fuel filters, GM AC lines) but what has anyone used a 20mm socket on? (other than to fill a peg on a Hanson rack)
speed bump
Butte Montana
I would bet that Ford would put them on something. Ford seems to try and justify owning sockets, wrenches, and various speciality tools in every flavor imaginable.
kartracer55
German cars use 9mm's in wierd places. I remember having to work on a porsche 928 or 944 or something (cant remember which it actually was) and the thing had 9mm fasteners instead of 8 or 10 it was totally aggrevating.
Oddly enough, craftsman sells 9mm but not *10mm* deep 3/8 drive sockets.
As for the 20mm, I have no idea, mine just fills up the peg....
*EDIT* - I screwed up, I meant 8mm. Of course they are going to make a 10mm deep
TheToolMan
N.J.
Ha, it is so funny that this thread came up because when i went to the flea market this weekend all i was looking for is a 9mm 1/4 drive deep socket, i exploded my craftsman one on friday pressing in a bearing on a damaged tachometer shaft, customer didnt want it machined, he just wanted new bearings installed, i havent found all the parts of the socket yet
Moose-LandTran
Apparently Chevy S-10 Gearboxes use a 20mm Somewhere. Between my shallow, deep and wrech all in 20mm, none have ever been used.
25mm is another odd size, but i've used mine a couple times. Cam pulley bolts on Cosworth YB engines.
Charles (in GA)
50 mi south of Atlanta
I have a pretty decent set of Whitworth wrenches and sockets that I bought from a co-worker. His father used them to work on Norton motorcycles. Whitworth was also used on certain British aircraft engines. The Rolls-Royce Merlin (think P-51 Mustang, or Spitfire) uses Whitworth sized hardware, as does the Roll-Royce Dart turboprop engine (Vickers Viscount, Convair 600, Fokker F-27).
Charles
Junkman
Northeastern CT
I once bought a car in 1967 that had a very large tool box in the trunk that took 2 very strong people to extricate. It was filled with both Metric and Whitworth tools. At that time, Metric tools were just about unheard of and I had no use for them. Gave everything in the box to a friend for his kids to play with. I kept the box for myself.
billymade
New Mexico
Charles, how are the sizes marked on the tools? How can you tell a wentworth tool from a "normal", "standard" one? Do they still use inches as a increment? Sorry about all the questions, I just haven't ever seen these type of tools before!
CatfishXpress
A big piece of steel in the Gulf of Mexico
My dad bought his first metric tools in the early 70's to work on a Datsun truck he had. He bought a cheap set because he thought if the Japanese were going to continue doing business in the US they would eventually have to convert over to SAE.
ImportTuner
That was what everbody thought in the 70's ... metric was not going to last ..
Lightning
Not only did metric last, but it is becoming more popular and I believe SAE fasteners are going to be very rare in the not too distant future. I use mostly metric tools and only occasionaly SAE sizes.
I rarely use the 9mm and 11mm sizes. The sizes I use most are 8mm, 10mm,12mm, 14mm, 15mm, 17mm, 19mm. The SAE sizes I use most are 9/16 inch and 3/4 inch
speed bump
Butte Montana
Depends on what you work on. In HVAC/R we don't even carry metric tools becuase you never need them. In most industrial location I have worked at I have never needed a Metric wrench to work on it either. The only things I have used metric tools on are vehicles and airsoft guns.
Jay H 237
Torrington, CT
Charles
Are some of those Craftsman Whitworth wrenches?
MAD
Western MA
Whitworth uses "WW" after the sizes to denote it. So you'd get a wrench marked 1/2" WW.
I have always seen Whitworth sizes marked with a single "W" after the fractional size. The King **** and Stahlwille Whitworth sockets I have are also marked with the British Standard size as well with a "BS" or "BSF" after the fractional size. For example,the 1/4" Whitworth sockets are marked: 1/4 W and 5/16 BS. The 1/4" Whitworth socket is close to the size of a 1/2" SAE (across flats) socket.
edit: This table shows the sizes.
http://www.samstagsales.com/whitworth_table.htm
