jb442
I'm fortunate to have a 3 car garage, and, on the "third" side, the cieling is vaulted and is essentially just wasted space. I would like to build out this area for storage. I'm pretty handy, but I haven't done much framing before so I thought there might be someone out there who has done something like this or knows about framing, etc.
I've attached a picture of the garage so you can see what I'm working with. (Sorry if I get the terminology wrong in the following...) The area is about 13'6 x 8.0' ~ 108 sq.ft. My plans were as follows: Line "B" -- 8' 4x4 from main beam to wall. Wall "A" -- Remove drywall and double-stud down to the mudsill. I would then connect seven 2x4, 13'6" joists, spaced at 16", from wall "A" to the 4x4 at line "B". They would sit on top of the stud that was attached to the existing studs in the wall. Between each of the A-to-B joists, I would bridge across them at various locations with 2x4's (not sure how much is really necessary).
So, my questions are... Does this sound feasible & safe? I would like for the area to hold as much weight as possible (within reason, of course). To finish, I would top it off with 11/32" plywood... Oh, and lastly, the garage door opener would be re-mounted to the bottom of the storage area.
Any ideas & advice is appreciated... Thanks for your help!
-John
-John
