I am an electrical retard
davesnothere
phoenix, az
And I'm hoping one of you guys may be able to help me. Came home from work today, and there's no power in the master bedroom, bathroom, and half the living room, which all share a breaker. So I checked the breaker, and the others while I was it, and they are ok.
That's the extent of what I know to do, and I don't feel compelled to start any type of uneducated experimentation.
Can anybody tell me what you might go about doing next? I called the landlord, who said call joeblow handyman, who's voicemail tells me he is out of town until Tuesday. If there's something simple I could do myself, id rather not wait that long.
Thanks guys.
D
davesnothere
phoenix, az
I've flipped the breaker more times than I can count, and get nothing. Everything else in the house is working, so I'm assuming its a problem with just the one circuit.
mrb
my guess is a failed backstabbed receptacle. Get a non contact voltage detector. Turn the breaker off and note all receptacles that dont have power. Turn breaker on and see if any of those now have power. Mark the one(s) that now work, turn breaker back off, pull out each of these receptacles and look at the back for melting or burning.
rburke65
Canfield, Ohio
Possibly a loose connection in an outlet. Go around to each outlet and hit the wall and this possibly will cause the connection to "make" momentarily and the lights, etc may flicker and come back on. That outlet is the one to take apart and to check out. No promises. Depends how it was wired. Good luck.
ghnl
Mebane, NC
Any GFI outlets in the circuits? Even if not 'tripped' they can fail and will take out anything wired downstream.
D
davesnothere
phoenix, az
I think I have a voltage detector around here somewhere. Do you just put one probe into one hole, and the other in the one next to it?
Teken
The Bad Lands
I would follow mrb suggestion. Its safe, practical, and it will at least rule out something you can do while you wait for the landlord to get the jack of all trades, master of none on site.
Teken . . .
D
davesnothere
phoenix, az
Thanks guys.
Found a GFCI tripped in the bathroom.
I didn't even realize there was one in there, as I'm not allowed into that bathroom.
That's the girls bathroom.
Speedy Petey
NY State
Dude, I was the first to label myself an electrical retard.
I also stated that the landlords professional, whom I did call, is out of town until Tuesday.
And I'm sure he is the only "professional" in town, right? :rolleyes:
Your LL sounds like a real winner.
Glad you got it worked out.
FluxCore
Born and raised in Germany, settled in Lousyana
Yup, glad you found it....but hang on, it's time to investigate why the GFI tripped.
Your little girls might be using something electricly unsafe, or did something unsafe...Perhaps the GFI saved them but the hazard remains.
Best case is maybe their little fingers accidently punched the test button...either way, investigate. :)
On a side note; That sounds like quite a load fed off a single GFI outlet
D
davesnothere
phoenix, az
I don't think it was the little girls, its more likely it was the big girl (read: my wife), and all her hair tools. At least she looks good. And now I know where to look first if it happens again.
NWphotog
If you mean voltmeter NO! You want to use a non-contact voltage detector. It has just one probe and all you have to do is get it close. Should be about $15 at a big box store.
FluxCore
My last wife had quite a collection of tools...One was 30 amp 220V-it had an impact feature and was variable speed...it was also carbide tipped...she chipped her teeth with it....After I got the electric and dental bill, I swapped it for a 13HP gas powered unit and made her use it outside....Yup, I did :)
She never tripped a breaker or GFI, but she certainly dimmed the lights with it.
gayler
Lakin Kansas
What the heck kind of tool are we talking about?
FluxCore
heck, I'm not sure what you'd call it....She bought it off the internet....It kinda looked like a small jack hammer...had two handles, and on the left handle was a squeeze paddle that controlled depth, the right handle paddle controlled speed....if you then twisted the right handle with the paddle squeezed you could control rotational speed...it took quite a bit of determination and dexterity to work it properly...I knew I had it right when her eyes rolled back in her head.
I remember she pitched a hissy fit when I used it to vibrate the concrete for my shop footings.
Falcon67
Merkel, TX
The big girls can certainly pull a lot of amps. :D
wb2vsj
East Coast
Oh, Man - I've got tears rolling down my face! :lol:
coolreed
Oklahoma City, It's a Windy Heat.
Most likely you have a GFI tripped. The GFI may or may not be where you think it is.
I had the same thing happen years ago and could not find the GFI. After considerable frustration (and I am a EE). I found the GFI in my bedroom hinden behind my High Boy chest of drawers.
Good Luck.
FluxCore
Good Luck.
I LOVE GFCI breakers.....25 bucks each....and Gawd do the EVER work with never a false trip....so far:)
TheChanMan
The First Coast, Florida
absolutely priceless. nice lead-up. i pissed myself after this one came full circle
