FordExplorer
- Joined
- Jul 4, 2012
- Messages
- 76
Today I bought a 1980's 6 drawer roller cabinet with a 10 drawer top cabinet for $100 and it even came with keys! The only problem is that it was fairly rusted. It was in a body shop and a lot of splatter hit it over time. The drawer bodies are spotless except for the fronts which are nasty. The cabinet has some rust on it and it needs to be refinished. The original color scheme was all gray with contrasting shades b/w drawers and body. The handle trim was a composite plastic with a red bead down the center.
Since only the fronts show any wear, I am only going to paint the fronts. I already sanded down the fronts of all of the drawers to remove any rust/ loose paint. Before I did that, I was able to remove the drawer trim so that I don't need to mess with taping it off. Currently two of the drawer fronts are in primer and they look really good so far.
My question is what painting process do I need to take from here. I am planning on doing 2 coats of primer with sanding after each to make sure it is smooth. Then I will do 3 coats of satin black rustoleum for the drawers and 3 coats of regal red rustoleum for the cabinet frame. Will this be enough, or do I need to spray clear over the color? I will add pics tomorrow sometime.
Does anybody have experience with doing a basic paint job like this? I see a lot of threads on some pretty amazing paint jobs where it turns out like a mirror. I don't want or need that so I figured that I would be good with what I'm planning now. However I wanted to double check and see what you guys think.
I will sand it out and then it should be fine. For some reason I started to use paint thinner to clean up the PRIMER?!?!?! Then i caught myself and I obviously didnt sand it out good enough. Also, sorry about the feet in the pic. I didn't catch it until I was already ready to upload.
