But I did mount a name plate for a co-worker that I TIG welded from steel to an Aluminum base......
I drilled both pieces, countersunk each..... then..... welded over the steel side to hide the screw...... and welded the nut on the Aluminum side (in hindsight...... I should have left that part alone so I could tighten the nut afterwards......)
Here are some pics of the steel and aluminum mount.....
The Steel side....
The Aluminum Side.....
The filled in Steel side before grinding....
The welded nut on the Aluminum side......
The final result of the two together....
The Steel side....
