2x4 vs 2x6 garage walls
brohr
Hi guys,
I am planning on having a garage built this fall. I have a good idea of what I want (28 x 40 x 10) with conventional framing and block foundation) and have priced it with a couple builders. One builder insists on 2x6 walls. Is this recommended vs 2x4 walls. I am trying to be as cost effective as possible. I don't plan to insulate it anytime soon either. Also, anybody know of a builder/contractor in northern/central Ohio area that may be interested in providing me with a bid to build this for me? I would really like an amish builder but would be happy with any qualifed person willing to build and do a great job. Thanks in advance for any input guys.
Mickey O
Chicago, IL
2 x 4's are more than sufficient for a garage (most framed garages use 2 x 4's), 2 x 6's will give you a stronger building with the ability to achieve a higher insulation R value and a bigger bill for construction. You live somewhere where there's some sort of natural disaster problems (earthquakes, tornadoes, hurricanes, etc.)?
Big-Foot
Midlothian, TX
X2 - not to mention more capable of carrying snow load..
Most 2x4 studs these days are total ****.
brohr
Hey, Thanks for the input guys. We do get some strong winds occasionally here in Ohio in the summer storm season (50-60mph) is not all that uncommon a few times a year. I do plan to insulate at some point so I will most likely go ahead with the 2x6 walls. I figure its shoudn't be but a few hundred bucks more to upgrade.
NUTTSGT
Northern Central Ohio
North Central Ohio, spend the few extra bucks on 2x6 walls, fill them with R19. Insulation is an investment and you'll apprecaite it later on when it 12-15 degrees cooler inside than it is outside on a day like yesterday and nice and warm when it's 12-15 degrees outside.
Where exactly are you ? It helps to put your location in your profile when you ask for advice. No need to be exact but it will help others help you, even a county like Crawford or Richland will help if you choose not put your city.
Welcome to GJ.
pain
Buckeye, AZ
2X6 is a bettr structure and more capable for higher R values. Are you planning on putting a loft in? If you are, that is another reason to go with 2x6 construction. Good luck and keep us posted.
carpenter383
2x6 walls are worth every penny in my oppinion for r value and especially strength if over 9 ft tall
