Anyone Identify This?
nine4gmc
Dallas
I have several items that I am unsure of what they are, I will post them here. If anyone can help, thanks in advance!
First, this thing I posted in somone elses thread. It has 3/4" in and out like a ratchet extension but it is big around and hollow inside. It came in a lot with a Proto 3/4" breaker and Cornwell 3/4" extension. Name that part:headscrat
Next up, CLUTHE made in Canada. The tip is hollow and spring loaded in the handle. WTF is this?:headscrat
No idea what so ever...:wtf:
There will be more.
kidney
Last picture looks like some kind of locking mechanisms. The narrow part would allow the piece to move and when adjusted to the thicker part it would lock it into place.
Almost reminds me of the handlebar lock off a motorcycle.
Just a wild guess.
Chris Stapley
Campbellford, Ontario
Last one is the quick release detent pins on PTO shafts used on Farm Equipment, many different ones made over the years..Kept them in stock when I sold Ag parts.. Going to suggest that the first picture of the shaft is also a drive shaft of some sort used in the farm trade,may be a partial drive shaft or cross shaft for a haybine ??
picshooter
The Cluthe looks like a brad nail tool, You insert the nail into the end and push.
N
nine4gmc
Dallas
Ok, the Cluthe tool turns out to be an electrical pin removal tool. The spring things are PTO releases.
That first thing still has me stumped.
jrlp
Laredo, Texas
The first item almost looks like the sliding arbor in a tube notcher for hole saws.. almost.
It's hard to tell if it spent most of it's life in one positions, as I can almost make out bearing marks about 2-3" back from the male drive end. Since it came with a breaker, I'm assuming it's meant to slide into a hole with slight clearance, and engage a female arbor attached to a gear. So you can manually rotate the mechanism front/back with the extension / breaker. But I'm known to be wrong most of the time!
Captain-Matt
Funny pliars are fencing ones. Notice how the pliar end has a pointy ended jaw to get under the big staples and is curved to allow them to roll and get purchase when lifting old ones out.
Hammer end is obvious :p
As is the wire cutters in the handle closing.
brownfoot
NC
pliers are for wheel weights, cutter to trim the weights, hammer to install, hook to remove
#2 is a brad driver
Big-Foot
Midlothian, TX
#2 is a brad driver
These look right to me and I have both..
The first ne looks to be a big honkin' 3/4" extension for a torque wrench like I used in the service a bazillion years ago. Might also be for impacts, but most impact tools are black oxide coated.
N
nine4gmc
Dallas
#2 is a brad driver
we have a winner!! thanks, you are correct sir.
The 3/4 drive extension is just that, made especially for a SWENCH hand impact tool.
The last, the pliers, are most definitely wheel weight pliers. I have a set.
Charles
another winner here, just looked it up, thank you a lot!!
You guys are the best, thanks for the help!
N
nine4gmc
Dallas
who made this drill press, I can't find any casting numbers or anything.
and then there is this unknown thingamajig...
Provincial
Near Salem, OR
The unknown thingamjig is a base for a surface gauge. It is missing the parts that support the feeler or dial indicator, namely a clamp unit that goes through the hole in the adjustable arm and a shaft that goes into the clamp unit and to which the indicator is clamped.
Here is a link to a photo.
http://www.jjjtrain.com/vms/Media/measure_transfer/surface_gage.jpg
N
nine4gmc
Dallas
Got some new things for you guys, any ideas?
the lighter is for size reference, it is made of brass
and then there are these, stamped 1,2 and 3, threaded different sizes but same depth on one end, made of steel.
Provincial
Near Salem, OR
The numbered hex tools appear to be "knock-off" style hub pullers. Remove the nut from the end of a tapered axle shaft and replace it with one of these, then hit it with BFH to break the hub loose from the taper. It works some of the time.
Notice the calling cards from the BFH on the ends!
