mooman
Has anybody ever used a sprinkler or hose to keep their condenser cool outside?
I have a large Quiet Kool windowshaker air conditioner for my downstairs.If you do this on a regular basis, the minerals left behind when the water evaporates will ruin your coil.
You could collect the condensate water, and use that, as it is essentially distilled (at least for these purposes), but you would need a pump setup to use it.
The instructions even said it is normal for this unit to not drip condensate. The sheet metal bottom is formed so that the condensate runs to a depression under the fan and a ring around the fan blades picks it up and it gets blown onto the condensor coil.
It's been working fine for about 7 years is all I can say about it.
I did just go look at it real good since I'm talking about it. On both sides of the coil I see no buildup at all.
. . . windowshaker air conditioner . . . The sheet metal bottom is formed so that the condensate runs to a depression under the fan and a ring around the fan blades picks it up and it gets blown onto the condensor coil. . . It's been working fine . . . I see no buildup at all.
I work in a restaurant that has an AC that is a little undersized for the job. We regularly have a dedicated hose with sprayer on it to keep the coil damp. It makes a difference in our case, from 80* in the lobby down to 74*. The coil gets cleaned twice a month with all the other fridges and freezers. Haven't noticed any buildup as of yet, been doing it every summer for as long as I've worked there...going on the 10th year now.
