skyking
What brand ,what agrigate/media. Do you use it much. Is it worth having and taking up the room.
I have a home made cabinet in my 2 car garage and although it's not used on a weekly or even monthly basis at times I definately think it's worth having. I plan to make a new stand for it that will have casters so I can move it outside on occassion. I set mine up for both pressure and siphon feed.
....I usually keep blast sand in it for everything else, which I buy at the local concrete supply house.
Eric, Tell us you're NOT using ordinary white silica sand or "play" sand? Sandbox sand?
To the OP you may as well hear it here: there's a condition called silicosis that is deadly and it comes from inhaling sand particles. White silica sand in particular can cause this and an ordinary dust mask will NOT protect you either.
Allways wanted one but never had a big enough compressor until now i think? Is a 60 gallon sufficent or just barley big enough ?
A_Pmech - Thanks. I've used it now for about 35 years and it's worked well. I would probably do a few things differently though. The hopper should be about a foot deeper for faster drainage and I'd probably put in a bit larger window. I have glass cut at an auto windshield place and they last at least 2 or 3 years. And, as mentioned, I'd like to redo the stand and add casters ... all on my list of "retirement" jobs when I get there in a few years!Nice work!
I am and have been for at least 20 years now but thanks for the concern, Now I'll go black to using bad silica. Oh and my dads almost 80 now and he's used silica in his blasters for well over 40 years now. Him and his partner ran a sandblasting business from late 70's up untill late 80's and there both as healthy as can be. Solely using white silica sand.
That cabinet is identical to my Harbor Freight blast cabinet.Mine is the basic Clarke unit (same thing different brand as the rest).
Oh, ok then. Nevermind to the OP. Don and his dad say silicosis isn't really an issue so you don't need to fear dying an agonizing death in exchange for doing a little DIY stuff.
http://www.osha.gov/dsg/topics/silicacrystalline/endsilicosis.html
Save your concern I don't need it...
Oh, I'm not concerned about you at all since you're not. ....and won't stop using silica either.![]()
but since you're determined, party on, you think you know better
