Well, Here she is!
1934/35
Frigidaire
Fridge
Here's the tag on the back:
It was actually a lot cleaner in person than the ad would have led one to believe, which was a pleasant surprise.
After problems were discovered with Sulphur Dioxide and Methyl Chloride as refrigerants in consumer refrigerators from the 1920s (both very toxic if leaked), research began to try and find a safer alternative. This led to Frigidaire/GE developing what is called... (ready for the tongue twister)...Dichlorotetrafluoroethane, otherwise known as R114, which was a Freon that Frigidaire used in the mid to late 1930s before Freon 12 (or R12 as we know it) took over.
The good news is that R114 (as this fridge uses) is non-toxic (at least compared to Sulpher Dioxide or Methyl Chloride). The bad news is that it is very, very hard to find nowadays. While you can find it, it is extremely expensive and usually just available in much larger quantities than needed.
Now here is the question: Does it work? Well, to be honest, I'm not sure yet
I'm 90% sure it has what is known as the 'Meter Miser' compressor, which only has 3 moving parts and was a big success for Frigidaire back in the 1930s, so it is not the typical motor/belt/compressor getup. When I plugged it in at the seller's house, I couldn't really hear much but didn't have it plugged in for more than a minute or two. Also, the power cord has had a traumatic life so that will get replaced pronto. I'm really hoping that the refrigerant system is intact. It would be a bear to try and fix it with a more modern refrigerant (R12 and R134a are unfortunately NOT substitutes for R114) so I'm keeping my fingers crossed. However, even if I couldn't make a solid determination on it's mechanical condition, it was headed for the scrapper and I figured it was one more piece of Americana that could be saved.
That, and of course, it has just about the most gorgeous name badge I've ever seen:
Art deco lovers, eat your heart out!
That's all for now. I should have an update in about a week, then an exciting/interesting update in 2 weeks or so.
