I need some help of the more experienced members in attic ventilation. I live in a desert climate in California's central valley. Typical temperatures during June, July, August & early September are in excess of 100 degrees. We've had times of 100 to 110+ degree days for 5-6 weeks straight in the past.
This weekend's project was installing 2" styrofoam insulation on the garage door. I ended up blocking out the windows in the top bay & turned my garage into a cave. In doing this I've drastically reduced the daytime temperature in the garage. This little project has now morphed into a lighting problem that will need to be taken care of at another time.
Back on track. I'm looking to reduce the attic temperature in both attic spaces. First one is above the garage, attached 3 car tandem garage, the second one is above the house. Also looking to add insulation and would like some recommendations on brands here as well.
I'm looking for 3 fans & need some input on brands/models. For the attic above the garage this space is ~250 sq ft. It is not very large but gets the most direct sun exposure and the most heat in the afternoons. Its also responsible for increasing the temperature of the master bedroom closet 20º & Master Bedroom temps ~5º. I will be insulating this area as it currently does not have any insulation. Typical track home and building to the minimum standard they can get away with.
Second fan is for the attic space above the house. 1860 sq ft 2 story. East/West facing home.
Third fan is to fit in a vent cut-out in the garage that is 13"X17.5". I'm planning on using this one to help reduce garage temperatures and currently having a hard time finding one that will fit.
I would like the garage attic space & garage fan to be controlled by a thermostat. I would like the attic space above the house to be controlled both manually and with a thermostat. I have a mechanical & electrical aptitude and will be able to figure out the electrical part on my own.
What brands would you guys recommend for these 3 fan's? I'm looking for something that is solid & built out of metal that will give me a useful working life. Not looking for a big box store fan with bearings that will fail within the first year. Next is budget. After the wife getting her "backyard remodel" $10K & this summer's vacation I'm looking for middle of the road quality fans.
Next year I'll be looking into a whole house fan and more fun in the attic above the house with insulation. Thinking about renting a foam gun and shooting up under the roof trusses.
Any help with brand's models would be greatly appreciated.
It's summer, it's supposed to be hot. You are far better off sealing off any cracks and crevices that you find, ceiling lights, receptacles, switch plates, around windows and doors and ADD insulation.
