Garage 2 - 16 X 22
pitterpat
Indianapolis
Ok this is the 2nd, little sister garage to this garage: http://www.garagejournal.com/forum/showthread.php?t=143509 ,
As you can see it is junky and crowded now since I cleared out my storage unit. This it what it used to look like in the 1st photo. And now here is what it looks like now, photos 2 & 3.
In photo 2 you'll see that I mounted the peg board under the 2 white cabinets. Can I spray paint that peg board white....or will that ruin it?
Looking for ideas to get all of my stuff in there neatly. I will be taking the 4' x 7' metal table out (it is all oily and smells). The top is 2 x 8's and I have some to replace it with. I plan to rent a paint sprayer and paint the ceiling white to brighten it up in there.
I'm looking to put the blue compressor in the upper left corner in front of the VW, that is where most of the electrical is running.
The car will be gone in about 6 months, and there will be one VW(blue) in there. The yellow one is the donor VW for another one that I have sitting outside to restore. I need to get the other one's body solid is some places before I can put the body of the blue VW on the chassis of the yellow VW.
Also looking for some type of way to hoist up the VW's when it is time to change out the body's.
Thanks for any idea's.
Pat
P
pitterpat
Indianapolis
Oh sure, but get a spray primer from the paint store, not from rustoleum.
You can also roll it with a foam roller.
If I foam roll it will it clog up the holes? And if you foam roll it what kind of paint should I use; I have some really good primer from Porter Paint, should I use primer? The reason I don't want to spray is because it is so hot in there and too much **** flying in the air.
