not bad for free!
1930artdeco
Lynden, Wa
A coworker asked me if I wanted so 30 wt. oil for my car and I said sure thing. Hey, it is free and it was a case. So he shows up with these babies. I think I have a press spout around here somewhere. But I don't know if I have the heart to use them because of the cool factor.
Mike
E.T.Privott
may i be the first to say......... boy howdy, that is one hell of a gift !!!! i know it was a freebie but you need to buy him lunch for a week, damn !!! that sure is a great find.... gift..... like i said may i be the the one to say....... well, you know !!!! lucky... lucky.... lucky....
cowboy73
southern Indiana
Those are really cool! You might consider letting the oil out of them though if the cans are paper. I would just punch a couple of small holes in the bottom and let them drain into another container.
gsmornot
Inside your screen
This post officially makes me feel old. I remember using those not so long ago. Lunch for a week? :lol:
Yep, same here. I remember using the cans and bet my dad still has the spout. I remember not long ago too using an adapter for gas that slid on the pump to put leaded gas in an unleaded inlet. Remember the leaded pump nozzle was a larger diameter.
Moose02
New Jersey Shore
I remember my dad bringing home bottles with a milk bottle like metal container with a handle the glass bottles that had the spouts on them.
TwoInch
NW INDIANA
dont use it, leave em original is my vote!!
and i wouldnt put that oil in an engine. if it had been stored in a controlled environment where the temperature has not fluctuated much or often, then it has a indefinite lifespan. the problem arises when oil sits in a garage, shed, an attic, or anywhere there are temperature swings daily and seasonal. temperature drop or cooling is what causes permanent thickening and waxes to form in mineral oil. 10, 20, or 30 years of daily, and seasonal temp swings will have broken down the oil makeup and viscosity. but sitting in a heated and air-conditioned environment, the oil would be more likely be very similar to "new".
there is a reason car and oil manufacturers call for x,*** miles OR X months change intervals. even a vehicle that isnt being driven, the oil still breaks down and thickens. oil that is subjected to freezing or near freezing temps are the worst victims, and need to be changed definitely once the weather breaks and is not dropping so low. oil sitting in a bottle is no different. if you plan on hoarding oil stashes, keep them in the house, or climate controlled somehow for long term storage. oil companies "shelf life" is not only marketing gimmick, there is some truth to it.
camarotoolman
cocoa Fl.
Are they paper or tin? Some oil cans are worth some good money, I think those go for $3-4. I drain them from the bottom, so they still look good on a shelf.
lotsoftools
Inland Empire
I remember using those when I worked at a full service gas station in CA. I still have a spout hanging around my shop for some reason.
nehog
Jaffrey, NH
As oil, it is too old to use in a modern engine (doesn't have the right properties) but I suppose it could be used in an older vehicle that doesn't require a lot of its oil.
However, like the others say, just keep them for looks.
jwith68
EC Missouri
Very cool as display items! As has been said, probably not good for a modern engine. I see it has API classification SF-SE, which would probably date it to no later than the early '80's. Current API class is SN, so there have been a few since those were made.
Thirsty
Sparta Wi
Sell them on EBAY and keep one for yourself to look at. I suppose you can't ship oil ?, I don't know? I know you can ship mineral spirits.
1930artdeco
Lynden, Wa
I am thinking along the lilnes of TwoInch that it may not be in that good of shape. I was going to use it in my Model A which doesn't necessarily need super top notch oil. Although it would probably be better than anything they had back then. But I am thinking wall art.
Mike
JasonW
Orange County, California
Probably about right. It has a modern UPC code so I was thinking late 80's.
darkk
Willimantic, Ct.
I must be really old then. I remember I used to buy oil in a glass bottle that had metal spout tops with a push on cap similar to this one if you didn't use it all...
Hootbro
Delaware
I am simply amazed the oil has not leaked out. Even new, I can remember cases on the shelf just seeping oil and making a mess.
kbs2244
If you have no personal use, take them to your local car show trade mart.
They are defiantly collectables.
FakeName
San Diego, CA
He hates the cans!
porschedude996TT
Santa Maria, California
When I worked in a Texico Service Station, in the service bay we had some oil in bulk, but the higher end stuff was not. It was in 1 gallon cylinder shaped cans like these only larger. I never see them anymore. Of course we had every type in 1 quarts in the pump lanes.
Did anyone ever have a push-on spout that was worth a S%i+ and didn't leak? I always kept mine in a 1 lb coffee can with the lid on it.
FakeName
San Diego, CA
Or worse yet, crush the side of the can instead of pierce the top?
I can remember working at a Shell service station (that's NOT a "gas station") and dripping oil on a hot exhaust manifold while adding oil to a customer's car during a fill up. Smoking like crazy from under the hood, the customer freaking out, pump barfing gas all over the drive because it didn't shut off like it was supposed to.
Had to credit the customer a couple gallons of gas.
At .59 per gallon.
TwoInch
NW INDIANA
At .59 per gallon.
$1.59? what year was this... 2001? around here gas was right around $1.00 until 2001
edit - i swear that said $1.59 when i read it first..... :lol_hitti
what year was it .59c? thats way before my time. i remember it around .90c, but no lower.
Big Rick
Billings Mt
MY first cash paying job was to sweep the floors clean the rest rooms and cut the steel tops and bottoms off the cardboard to burn in stove in winter
mikeceli
WHY? That would devalue them. There worth more as antiques than the oil. Probably won't leak for a long tome.
In 1985, My brother bought a shop w/ leftover ALL PAPER, oil "cans" from about the 1940's. They only seaped a very small amount, in late 1990's.
Cougar67
Virginia
It did, I edited to correct my mistake.
1976
Ha Ha! I was thinking: 59 cents = 1976 because I pumped gas that summer! We ran specials over the 4th of July for $19.76 cases of oil too... The whole bicentennial thing got a little tiresome from a retail standpoint.
