Anyone build a rest for sighting in rifles?
5lima30
Mountains of Western NC
I have been looking at rests for sighting in rifles. I currently have an MTM plastic model that doubles as a maintenance rest. It works OK for a maintenance rest but ***** for sighting in rifles. I just wanted to see what yall are using and whether I should buy a commercial Lyman type or build it. Show me what you are using!:thumbup:
MoonRise
You got's yer plastic ones.
You got's yer wooden ones.
You got's yer steel ones.
You got's yer cast iron ones.
You got's yer bag's o' shot or sand.
You got's yer huge f'n blob o' concrete ones.
Your call as to what's you want's ta do. :D
Trade-offs between cost - size - weight - portability - steadiness - durability
Field-rest for semi-informal plinking or sighting in? A 'field' bag. Maybe a front bag and a 'small' rear bag.
Little more 'serious' range/bench work? Front rest with adjustments and then a rear bag.
http://www.brownells.com/.aspx/cid=10037/k=/t=P/Products/Shooting-Rests
Hobbit
Bama
I have always used sand bag rests. To me they are quicker to adjust and there is almost "0" chance of damaging the finish on an expensive gun.
toymn6366
georgia
got one i'm working on know using a scissor jack,i think i have pics on laptop at home if interested
5lima30
I have a couple of bags that I use for informal shooting from a table. But I wanted something that I can keep positioned better from shot to shot while sighting in, but is reasonably portable.
72Wagon
Virginia
Here is one I built last year works real good, weighs about 25 lbs and has numerous adjustment for use on different size guns. This pic doesnt show the small shot bag on the front rest.
toymn6366
georgia
this is what i have got done so far at the back will be a padded clamp to use for bench cleaning that can be removed completely and just use the front rest to shoot off of at range its not heavy to carry.its made out of a honda [i think] jack,a boat trailer guide,china sockets for feet,and some scrap steel.i will try to finsh and get some more pics up.
72Wagon
Virginia
Yes it does adjusts for long or short rifles, has rear and front height adjustments, and side to side (level) adjustments. Even has an attached bubble level. The weight helps keep it steady on the lower calibers so repeatability is attained.
