Toolhorder
Anyone see this new power probe??? I may have to retire the PP3
Anyone see this new power probe??? I may have to retire the PP3![]()
I need to know if this new power probe can just diagnose the problem for me, lol
You just touch the probe to the circuit in question and the display is like, "change door look module"
anyone?
anyone?
Click on the link right above your post and then click where it says "where to buy"!
Only a few selected sellers will be allowed to sell and your looking aroun$500.00 but should help cut diag time! Snap on Matco and a few others but no retailers other than that. I already got one today just adding to one two and three. I love them![]()
it took the place of my ppIII and my multimeter best investment on diag tool ever
I have had mine for about 2 month's now and would not trade it for any other power probe tool out there
some of the features that are kick a** about this tool are
its an Ohm meeter
showes battery voltage and the voltage of the wire you are testing
has 10 circuit breakers built in ranging from 2a to 65a
has 9 ac thresh holds ranging from .1 to 50
has 5 voltage drop ranging from .2 to 3v
you can do current draw testing
you can measure ac peak to peak testing
you can test relay's
has arc detection you can check pulse count, duty cycle and positive and negative pulse with great for injectors (check time fuel injector is on and off), cruise controls, idel air control motors and fuel metering solenoids knock sensors, wheel speed sensors, cam & crank sensors
can operate from 12 to 48 vdc
volage measurements from 0-99.9vdc/vac
ohms from .001 to 15 meg ohms
amps .001 to 99.9 amps
has a latch on pulse or momentary power to tip or ground to tip
I would not trade my power probe for any thingit took the place of my ppIII and my multimeter best investment on diag tool ever
I give it![]()
Every tool has some value, and some people succeed with Powerprobe. But I'm disappointed that the LOADpro Leads I developed in a class in 1999 and patented in 2002 haven't been better promoted. At $70 people assume it doesn't work, and the tool companies have a harder time seeing a profit. It's a set of voltmeter leads you simply attach to your digital meter, and when you see voltage, you push the LOADpro button and immediately load the circuit to test conductivity.
The Powerprobe hook is $500 and more profitable. For $300 you can get the TMX 589 Tech Meter kit which includes a digital meter, the LOADpro leads, my 200 page electrical book and a one-hour DVD on meter reading and diagnostics.
If you read the voltmeter correctly, you only need to read voltage and load the circuit to recognize if it's open, shorted-to-ground or corroded (the only 3 faults in a single wire).
I know people will argue and say that it can't be that easy, but it it. I've been teaching electricity for 27 years and if there's one thing I understand, it's that people make it harder than it needs to be. The Powerprobe Hook is waaaaaay too complicated and has functions that really aren't all that helpful.
My opinion - but before you slam me (as I expect might happen) watch this and decide for yourself:
Ouch on the price.
I think you will be selling your current one to help pay for it. I do wish the showed what the heck the hook was for? (small wire amp clamp?)
