Wurth Car Petrol Engine Additive is it any good
jeff g
Manchester UK
Hi
Has anybody used this & is it any good, my bike is miss fireing a bit,
not been used a lot in the past 2 years. :(
Wurth Car Petrol Engine Additive removes resins and paint like deposits that form in fuel lines, fuel pumps and carburettors as well as: Prevents pinking Improves fuel economy Improves engine performance Lowers exhaust emissions Safe for use with all
thanks jeff
Hawk
Kannapolis, NC
According to the product website it is a fuel additive that has similar claims to Seafoam as well as many other products. I would say it might be worth a try but not to expect miracles.
79firebird
Victoria bc
All it is is re branded sea foam at more cost
Ive used it ive put it next to sea foam smelt them both and they are the same
Boomer343
Wurth actually makes some very good products and if it is like sea foam then it may help your bike. One thing not to do is use too much. Best bet is to drain the existing fuel, refill with new fuel and add the correct amount of the additive.
BTW what myself and others are now doing is to use a small amount of two stroke oil mix in the fuel. It needs to be the newer TCW3 rated product. It helps to stabilize the fuel and provides some valve train lube at the same time. Good for bikes that sit. If you can avoid fuels with ethanol in them that is a good thing to do as well.
79firebird
Victoria bc
So far ive only ever had 1 prob with sea foam. ive used it on all my toys. Only prob i ever had was on a desil ford with 500,000k on it. Put some in it to try to make it run a bit better but it ran even worse. Could have been unreleated i dont know. Truck was well used and abused. Owner only did a oil change every 2 years. and it was a 1998
J
jeff g
Manchester UK
Hi
thanks for the info :thumbup:
J
jeff g
Manchester UK
Hi
500.000k did you add a little prayer :dunno:
jeff
J
jeff g
Manchester UK
Hi
Ran a tank full of petrol with the Wurth in it & it is runing a lot better,
the miss fire has gone & the engin is pulling like a train :thumbup::thumbup::thumbup:
I would say it is good stuff, worked for me.
Pate
New York
I was a rep for Wurth for a few years. They really make some great products, but they aren't cheap.
