Greetings,
Huge fan of this forum, long time lurker.
I have a 2 car garage (my happy place), setting it up for compressed air. I am a hobby mechanic, but it is turning into my living. My place is townhouse style, so I want to keep things quiet.
I bought an Ingersoll Rand, http://www.amazon.com/Ingersoll-P1IU-A9-Carry-Twinstack-Compressor/dp/B0035HYJN4/ref=sr_1_1?ie=UTF8&qid=1343515167&sr=8-1&keywords=ingersoll+compresor and even that is too loud for frequent use.
I will need to build a NOISE BOX
Had idea to unbolt the compressor/motor and put it in a box made of this: http://www.homedepot.com/buy/building-materials-insulation-sheathings/1-2-in-x-4-ft-x-8-ft-temple-quietbrace-141134.html#.UBRqzrSe52A
Noise will be the easy part to control. Can put one box side on hinges, and line the edges with a gasket to seal air gap.
HOW DO I KEEP IT COOL?
Goals:
1) 15cfm (hopefully buy one big compressor on Craigslist)
2) Silence, hence the noise box...
3) Keep tight budget (can't afford to buy a $1000 Ingersoll Rand
Ideas to keep it cool:
1) Submerge the compressor in fluid inside box? (oil, coolant, etc?)
2) Setup a cheap car-style fluid pump, move fluid out of the noise box and through a heat exchanger?
3) ??? How would you do it?
Many thanks in advance!
.Had idea to unbolt the compressor/motor and put it in a box made of this: http://www.homedepot.com/buy/building-materials-insulation-sheathings/1-2-in-x-4-ft-x-8-ft-temple-quietbrace-141134.html#.UBRqzrSe52A
Goals:
)Ideas to keep it cool:
My biggest concern is the vibration, causing an improper build to fail, causing the seal around the compressor side to fail...
