What would you use it for?
CAOS
Land of Living Skies, Canada
Hey everyone,
Picked up this gear today from the local scrap yard, it was a workout trying to dig it out of the pile then carrying it to the scale. It weighs in at 132 Lbs. I plan on using it as the base for my 8" bench grinder stand.
Thought it might be interesting to see if anyone has any better ideas of what it could be used for?
Thanks for your time!
srmofo
SW ohio
that thing is damn cool. I think a base for pedestal is the perfect application.
kf4zht
Calhoun, GA
I think a base for a grinder is a great idea. I would try and find tube that fits on top of the center with a lip, rather than going over it.
C
CAOS
Yea a piece of 4" pipe would leave a nice lip to make a nice fillet weld. A buddy of mine had said how sweet would it be to find a shaft with the same splines to slide inside the the sprocket.
nine4gmc
Dallas
the shaft would be perfect, but a piece of pipe will do. nice find, my scrap guy comes by every day with heavy **** but nothing cool like a sprocket.
bad_idea
Pasquotank, NC
What kind of steel is it? Are you going to be able to weld to it? Is it cast? It may weld fine and make for good looking welds, but then crack the first time you stress the welds. Could make for a painful mess.
Hal
Vermont
What size chain fits that sprocket? :evil:
Not actually a sprocket but a gear, probably a bull gear from the final drive of a fairly big dozer or tractor. There would be a much smaller gear (the "bull pinion") driving it, maybe somewhere between five and ten to one ratio. The splined hub fits the end of the drive axle.
It could also be from some sort of industrial machinery, but the dozer was the first thing that came to mind.
Brad54
Throw it in a friend's trunk and forget to tell him about it.
-Brad
fourjeepin
Atlanta, GA
Cool gear. I found one similar in my local scrap yard, but it was a little larger and about 4" thick across the entire face. Would have made for great yard art, but they wanted $200 bucks for it. And it weighed lost 500 lbs - moving it would have been fun!
C
CAOS
As far as I can tell it is not cast, machined block of steel. If I was to mount a vise to it I'd likely preheat it, but since it's just getting a bench grinder I'll hit it with some 7018 without any worries.
jamesemery728
Put in the back of your 2WD pickup in the winter for extra traction. Would also make a grand grinder stand. Looks like a gear from a major piece of equipment.
coldfusion21
portland, oregon
We do gears like that at work. Some 3-4' across but only 6 or so inches high. Weigh almost 500lbs. Earlier this year a guy dropped one on his foot while removing it from the vertical lathe. Bad times.
If its for anything like a gear box or final drive it's a forging that's been machined and possibly heat treated.
taumac
Brooksville, Fl
Thats cool!!! I say put a piece of glass on it and use it as a table or something like that. I like it as a conversation piece. I seen ppl make tables out of engine blocks truck rims etc.
heres mine 200 to 300lb converstion piece just after I painted it.
View media item 22590
BD1
north side
OUCH !!!!!!!!!!!! Did he call a toe truck ???
C
CAOS
Sweet! What was it to begin with?
taumac
Brooksville, Fl
its know as a Vulcanizer Rubber Mold Hydraulic press. We had a friend that use to make her own rubber molds for casting her own jewerly pieces from pewter. The top and bottom are 1 3/4 thick and those nuts are 2 3/4 big. That is a 25 Ton jack and not in pic is the 3 14 in dia steel plates 1 is 1 3/4 thick and 2 are 1in thick. I never weight it but im 5'8 180 in good shape and I cant lift the top off without help. I say use it for art or something cool because you make a base for grinder out of any steel rim off a truck anyday of the week. Its not too often you find something cool as that. That just my 2 cents.
I found this pic of a similiar one
Tucko
Whittier, Ca
If you're a tough guy like me, you'd use it for a frisbee! LOL, but seriously...that thing is cool!
taumac
Brooksville, Fl
Remind me never to come to your neck of the woods or piss you off althrough you could save me airfair by throwing me back home LOL
goodspeed
If it was mine (and I wish it was), I'd make it into a coffee table. Build a frame for it and cover the top in glass. If nothing else, I'd make it a coffee table for the office in my garage. Who knows how the little lady would feel about that in the house. Lol
CheezyRiderAZ
Gilbert AZ
SWEET find!
That's the kinda thing I see someone carting out as I pull in to the scrapyard.....
It'd make a great base for a grinder, or a couple grinders, or even a vise......or you could make some kinda removable setup, like a receiver, that you could use for assorted tools depending on what you need at the time.
Keep in mind, if you have it inside your shop, garage, or whatever and you have to move it, you're likely gonna ding up any kinda floor coating if you have any....
rsanter
visalia ca
Make a stand for it and put a round piece of glass on top and you have a new coffee table or end table
Bob
