Anybody remember these?
Lomotil
South TX
Appears to be made fairly recently, given the markings, but I don't recall these ever being sold at the stores. I've seen the newer Chinese/Taiwan polished wrenches that look like this, but with a spring-loaded tab, but there was nothing anything like this on the shelves:
The open end looks very similar to a design by Westward, just with subtle differences:
Something that wasn't all that popular, perhaps? First time seeing one...
bobcatdan
Kaukauna,WI
Yeah I do, there is the complete SAE and metric kits in the shop. They were around for a year or two in the late 90's. They're longer then a normal RP. They work ok, but really just a typical craftsman gimmick tool.
They actually made them quite a while back and they have made a resurgence for an open end "ratchet" wrench...
I have one or two I found recently
L
Lomotil
South TX
I've got about 4 total (different brands) - but have yet to actually use one. Seems like it'd be easy to round off a bolt with one of these designs.
ndoran
I have a set in my box given to me as a gift. I have never used them and they must have sat in the box for 5 years now. I m considering cutting them up to make torque adjusters by welding on some old 1/2 inch drive sockets onto the cut end of the bit with the box end on it.
mvptrukin
Denver, CO
They were sold as another "speeder or ratcheting wrench" version. You could change handle position without taking the open end completely off of the fastener! I also thought they sucked.
Rickster
SE PA
I've got some of those! Picked them up a while back. I have a 4 pc set and a three pc double ended speed wrench set.
mudflap
cincinnati,ohio
I have quite a few of them, they do ****. But one good thing is when they break Craftsman has been swapping them out for the pro wrenches due to their length.
srmofo
SW ohio
Are those the "Quick" wrenches that CM was promoting as a ratcheting style open end wrench?
I think they were actually called quick wrench
2oolhound
BC Canada
Yeah, you know those times when the threads are so gummed up or there's side tension on the part and you can barely turn the fastener with your fingers? That's when we're supposed to grab for one of those. They aren't for crackin a nut or bolt, just those tight ones that are hard to turn after they're cracked loose. Plenty of other options and habits out there though so guess they weren't worth the trip to the tool box.
bluebolt
Benton LA
I have them, use them and like them. The best use for them is taking fluid line nuts off after you have broken the lines loose with a flare nut wrench or regular open end. When I ran an aircraft tool crib in the Air Force the hydraulic and jet engine shop guys requested them in their tool boxs. This was probably right around 1999. Never had any problems with them.
AZ_Catskinner
Morenci, AZ
I use mine like it's going out of style - they are the definitive wrench for those long hydraulic and pneumatic fittings.
nyrapscalion
Reston, VA
I have a set of the metric and SAE of those! I'm thinking they didn't sell. Something I never see at flea markets/garage sales is usually a bad sign. USA made..a good thing.
Jim85IROC
Yeah, Sears has something like these right now. There is a small difference though. The current version has a little spring loaded tooth.
My father has the Gearwrench version of those. It's got the non-reversible ratcheting closed end, and this spring loaded tooth thingie that you describe on the open end. I thought it was dumb as hell until I had to loosen the upper control arm bolts in the engine bay of his 65 Mustang. I now have a very high opinion of that little ratcheting tooth thingie. Loosening those bolts is nearly impossible on a 1st gen Mustang that's got headers. You can't fit a box end over the bolt, so you have to use an open end. You have to lift the open end off, reposition, then re-mount the bolt head with a normal wrench. This pseudo-ratcheting action allows you to save a lot of time.
Aside from that one particular application, I've still found zero use for them, however.
2oolhound
BC Canada
Similar to this?
Wrenchking's that are fairly old. Haven't been able to find out much about them.
Hey chopper1 those wrench kings are cool! Is there a grub screw pushing a spring on the back side? Got a photo of the back side?
I'm trying to figure out how they are supposed to work. Slide the open end 1/2 way on the nut? or is the 5/8 actually used on a 9/16 so the spring loaded insert engages? These wrench kings seem to be 1/2 way between normal wrenches and the newer versions we see in the other photos that don't look anything like normal open ends. They maybe offer just a slight advantage over using a regular open end and sliding off and on each turn, you maybe just don't slide it on as far. The newer ones on the other hand will never grip like a regular open end.
Chadwilliam1
Cincinnati
I have an sae set that I bought for my dad as present. 10 years later he gave them back in the same condition. I have still not used them.
monster1
i am fairly certain i saw these on the shelf at sears just last week.
Yep. Me too. Btw, I have sets similar to these in stanley. Never use them. Got them on clearence(wonder why) at a closeout chain store over ten years ago. At the time I thought I stuck a gold mine!:lol_hitti
chopper1
Member Emeritus
Ohio's North Coast & Florida's West Coast
I don't have a photo but there is a screw tensioning the spring. I did a quick look this morning but couldn't find them. I'm thinking I may have sold them at my garage 'tool' sale.
If I recall correctly, the open ends are larger than the standard 9/16 & 5/8 wrenches.
4x4gearhead
New Hampshire
I have a 10-17mm snap on set that I got for cheap money from my matco dealer years back, I find them to be handy when you have something a ratcheting box end wont fit on. Other than that they are hardly used. takes too much swing radius to be a viable all around "ratcheting" wrench.
luvit
mine were a gift from my mother. -- SAE, 6 pieces.
one of the few gifts i received that have been useful.
this happened prior to me posting wish lists for the clueless.
i am selective on how good of condition the fastener is when i use one of these wrenches.
i look for opportunities for their use. -- i like them.
they remind me of how there were occasions when time and thought were put into gifts from my family.
i didn't open them for 12 years until i bought my first real tool chest to prevent them from getting lost.
yes. i just opened them about 3-5 years ago.
