I received some great help here last winter that empowered me to frame out a triangular opening for my barn's attic. I am in need of some framing help again.
I am framing out what will become a long shelving unit on the raised portion of my upstairs barn floor. Let's call it a loft area, for lack of a better term. The shelves will hold books, primarily. The unit will also keep people from falling off the edge of the floor to the open staircase on the other side.
Now, I will have two bottom plates, one for the back of the shelving unit and one for the front. I will then need two corresponding top plates, attached to the angled ceiling, for my studs to connect to. I could probably monkey some way of determining the locations for the top plates, using trial, error, sweat, swears, and an assortment of wood scraps, levels and pencils. But, I am sure there is a right way to do it.
So, with my bottom plates in place, what is the best/easiest/most proper way to determine the positioning of the top plate so it is directly above the bottom plate?
Here is the space in question. You can see the first bottom plate in place.
