DucFanDan
Hello all,
I've been lurking around here for a while as I shop for a lift. I'm outfitting a new garage. Concrete is all good... have over 6" of 3000+ psi rebar-reinforced concrete, and it's been in place for a year.
I already know what category I want for a lift. Going for a 9k+ 2-post. I need to lift everything from a 2400 lb old VW GTI to a 2011 Silverado 2500HD Duramax that tips the scales at 7500 lbs. I'm in the aerospace industry, and I like safety margins, so I would never put that Silverado on a lift only rated for 7k.
Given my needs/wants/etc, little lifts like the MaxJax are a non-starter. I have more overhead clearance than that, and it's not beefy enough for my truck.
The issue I'm running into is that my overhead clearance is not quite enough for the average 12' lift. Garage is 24' wide, with a ceiling that slopes from one side to the other. I have about 14' on one side, but only 8-9' on the other. When I lay out the footprint for a 2-post Bendpak XPR-9/XPR-9D, one of the posts only has 134" of ceiling clearance (11'-2"). Most certified 9k lifts are 12' (143"-145").
So I'm looking at the following options:
Dannmar Admiral 9000X (113", ALI-certified)
Bendpak XPR-9 (113", non-ALI-certified)
Forward Lift BP9 (111.25", ALI-certified)
Rotary/Revolution RTP9 (111.25", ALI certified)
I really like all the engineering info on Bendpak's website. I like their design, and the 2-post comparo pretty much sold me... but the XPR-9 is not ALI/ETL certified. Now I'm reading that code across the country specifies that an installed lift must be ALI/ETL certified. For the immediate future, this lift will be for personal use only... but the next time the aerospace industry shifts, if I were to lose my job, I am considering setting my shop space up to where I could start working for myself as a mechanic/restorer/car builder. Obviously, I wouldn't want to have to swap out the lift just to start a business. With this in mind, I'm hesitant to pull the trigger on the XPR-9.
Throwing a complicating wrench in the works... I could potentially knock a hole in the sheetrock ceiling and box in a space for the top of the lift. Then I might be able to squeeze in an XPR-9D, which is certified. I have 16" between the sheetrock and the outer sheathing under the roof, and I'd need about 11" to stuff the XPR-9D into there... so I have a margin of error of 5". I'm just not 100% sure on the measurements, not sure 5" is enough margin, and I don't want to go cutting into the ceiling unless I'm committed to going that route.
I guess I'm particularly interested in opinions on the 4 options I linked above, as then I avoid the construction project and risk associated with modifying the ceiling. At the same time... what I really want is a certified BendPak. What say you? Am I thinking too highly of BP's hardware? Should I just get the Dannmar or Revolution or Forward and enjoy working on my cars with a real lift? I'm thinking any of the above lifts would be better than rolling around on the ground like I do today...
Thanks in advance!
Thanks in advance!
