Drill chuck
ColoradoDoug
CO
I have a 15" Clausing drill press that currently has a Jacobs Super Chuck with a #2 morse taper. No. 11N 0-3/8" is stamped into the chuck as well. I want to purchase a chuck more in the 1/2" or 5/8" size. As long as I find a chuck with the #2 morse taper, will I be fine? When looking at chucks, I see for example; Jacobs 34 #2 morse. What is the first number on these chucks, just a part#?
Provincial
Near Salem, OR
It sounds like you have a pretty good drill press. It deserves a good chuck. You now have an 11N Jacobs, which is the best series chuck Jacobs makes. The 11N is the smallest of the series, the 14N is the 1/2" capacity version. The 5/8" capacity 16N only goes down to 1/8", so you would have to change back to your 11N for smaller bits. The Jacobs chucks are now made overseas, and I have seen posts critical of their quality. Would you be satisfied with a good used chuck? If so, many are out there.
Most industrial chucks are built with a female taper in the chuck body. An adapter with a taper that mates with the chuck taper is sold separately. What you need is a chuck and an adapter that has a #2 Morse taper for the spindle end.
The chucks will have a taper number on them. Heavy duty chucks, like the Jacobs or Rohlm ball-bearing chucks, will have numbers like 2 or 3 that indicate the taper. Both the 14N and 16N have #3 Jacobs Taper bodies. You can buy a #3JT to #2MT adapter quite inexpensively from a tool supply company.
You can change the taper adapter if a used chuck has the wrong one installed. Jacobs makes wedges for removing the old adapter, and a well-equipped machine shop should have a set.
C
ColoradoDoug
CO
I've been looking at used USA made Jacobs chucks like what I have, just in the larger size using a #2 taper.
Provincial
Near Salem, OR
Doug, also look at bare 14N and 16N chucks. The adaptors are readily available and require no tools but a small press to install.
Limiting yourself to #2MT package deals will really make it hard to find a used one.
Davefr
OR
I think the sweet spot for your drill would be a Jacobs 14N (ball bearing) or Albrecht C130 (keyless). They are both 1/2". I don't think you'll find too many applications where you need to go 5/8". If so, I'd skip over 5/8" and go to 3/4". (ie Jacobs 18N).
There are tons of chucks on Ebay but most of them have worn or damaged jaws so if you don't see a detailed image of the closed jaws and inside surface then avoid them. You also need to ask the seller if the chucks open and close without any tight spots. They usually won't say in the ad. Jacobs rebuild kits tend to be pretty expensive.
You might want to checkout Llambrich at Zorotools. They are less expensive then Jacobs and still made in Spain vs China. (Llambrich used to make chucks for Jacobs)
Davefr
OR
No, you don't install a chuck arbor with a press. A couple taps with a soft mallet is the correct method.
However to remove an arbor you often need a press and some good luck. Wedges don't always work.
C
ColoradoDoug
CO
Thanks, I will look into those.
larry_g
oregon
