My new IR W7150 kicks @$$.
Does anyone here use a cordless impact wrench? Are they as good as air impacts?
I have a craftsman 19.2 volt 1/2 impact its rated at 200 ft lbs. It does most lug nuts assuming the batteries charged. I use it daily in a shop and for the price its impossible to beat. I think a 3/8 is in my future for lighter dissasembley and tight spaces. It doesnt compare to a air powerd impact power wise its just nice not having to get the air hose out and it does 80% of the stuff. Its also nice for changing tires and things away from the garage.
The best 1/2" cordless impact for the money is Milwaukee's M18 at under $400. Its what i use at home and is probably the second strongest cordless out there behind the IR W7150
08-23-2012 03:13 PM/QUOTE]
I with you on the milwaukee 1/2 impact thats one nice gun I like it so much I went and got the milwaukee 3/8 drive cordless ratchet and I now use that more that my air ratchet milwaukee is my go to tool now![]()
It depends, Bosch has a large family as well. And depending on what you are getting one brand may have better tools in that area you need. But the milwaukee has a very good m18 line up. Can not go wrong with them. Saw the Bosch seems a bit nicer with their jigsaw, saw saw, band band. Milwaukee has the fuel hammer drill and regular drill and 1/4 compact impactor that are very good.
Rotary hammer the Bosch is super nice with the brush motor, bosch and hilti makes the best pro grade rotory hammers.
Id pretty much stick with drill impact driver recip saw grinder and impact wrench
My 18V Milwakuee is so heavy (V18, older not the new M18) and my DeWalt 3/8" 12V is too weak to break lug nuts so I am looking forward to air. I know my pancake compressor will be the next problem, it never ends around here. Perhaps I should be done with it and just get an M18 or the new IR![]()
I dont have access to a decent air supply (mobile), so I bought the older IRW360 about 5 years ago. I have to break the odd fastener loose with a breaker bar but for the most part I dont really miss it. I also use a 10v 1/4 hex impact which has replaced my little air ratchet.
Step up to the W7150. I owned the W360 and it's no contest when it comes to power. It's just like having an air gun with you, but in cordless form. My Snap On CT6850 (with lithium) is powerful and will take off axle nuts, few crank pulley bolts, and every lug nut minus 18-wheelers, yet the W7150 trumps it. I have a 2135Qtimax and a couple Snap On MG725, but the W7150 keeps up with them no problem.
But if someone wants just a single battery/charger, then you can't do much better than Milwaukee or even Bosch. They have almost everything under the sun.
Rigid 14 volt Impact Driver with charger
How can I tell via pic what drive size this one is? It's from someone's for sale ad.
