Breaking in new pliers
solitaire
Any fast and easy way to break in a new set of stiff opening action of new klein pliers? I tried soaking them in ATF for a while
sickjuice
welfare provence
No one has problems with this? Am I that weird
I'm serious about the cutting oil. I'm an electrician so I've broken in a pair or two of kleins... Once I had a pair of side cutters that were still stiff after 6 months of daily use and a guy showed me to use cutting oil.. Had them loosened up by the end of the day
Matt018
I had the same problem with some channellock side cutters. just work oil into the joint and use them. There smooth now. Or buy knipex, those are the nicest pair of diagonals ive owned.
rkevins
Central Arkansas
at work we use wd40 at the end of the day spray it in the joints and work them, you may have to do this a few days in a row, and again if you cut mc cable with the a lot
I like mine loose so they fall open in my hand, so I can move the handle with my pinkey
rlitman
Long Island
They break in, and get better.
When I get a new Leatherman tool, I'll sit down at a TV show, and keep opening and closing them over the full range of motion for an hour or so. A few hours into this, and they're getting pretty good. I'll then soak the joint in White Lightning bicycle chain lube. Use some extra, and flush out the metal dust you created while breaking everything in.
After that, it'll be smooth as glass.
RECox286
South Joisey (yeah, that is part of the USA)
Don't youse guys know the trick ? (Here is one my father taught me.)
Take yer rusted and tight pliers, or new tight pliers for a swim under the
hot water tap while exersizing them. They will loosen up in just a minute
or two. (if you don't have really hot water, boil some in an old pot, it works
just as well, if not better. When the pliers are working, let the water dry
(being hot, it won't take long) and follow up with WD-40 or the like.
Uncle Bob
Rtw5150
Spray them down with pb or wd then dip them in silica sand, then work em back and forth. That's what us electricians do to a new set of Kleins around here. :D
Gert
Netherlands
I have had good luck with Ceramic glass cooktop cleaner made by HG.
http://homeathome.homehardware.ca/e...op-Cleaner/_/N-ntjwqZ1z141rj/R-I4521773?Num=1
It is a very mild liquid abrasive.
Add the liquid to the joint of the plier and open-close it multiple times.
The one plier I mentioned took about 10 minutes to free.
Add more cleaner when it gets dry.
Than clean with lots of water, dry and apply wd40.
Most chrome polish liquids have the same ingredients, so you might give that a try as well.
KinzeMech
Run 'em dry until you feel them wear in.
Lubrication slows down break in wear. In the short term, it makes it feel smoother, in the long term, it's taking it longer to wear in.
None of mine that ever started out stiff stayed that way after two weeks of normal use with no special care whatsoever.
mrbreezeet1
Moundsville, WV, 15 miles South Of Wheeling WV
what is cutting oil going to do that any other oil wont?
I don't know how well I can explain it, but the way I was taught, and IIRC,
It's something like,
say, 3/1 oil, or motor oil, lubricate and separate the metals, where as cutting oils, lubricate to a point, and also cool, and let the two metals get together and "cut".
That's about the best I understand and can explain it.
AutoTek
SF Bay Area, CA
I had a new pair of channel lock cutters that were pretty stiff to open and close, tried wd40 for a few days didn't work, so I ended up wedging a small screwdriver in between levers and gave it a quick tap, cutters have been great ever since....
KinzeMech
(Guessing here) Ordinary oils are designed to lubricate in a way that prevents or minimizes metal on metal contact/wear. Cutting oil is designed to lubricate in a way that enhances metal on metal contact/wear.
Use an ordinary lubricant on a tap, or at a drill press. Then use cutting fluid. You will see the difference in how it works.
96snma
Calgary ab/saskatoon sk
My buddy who services sub stations gave me a set of cold klien side cutters. They were still sooooo stiff and could hardly be open. Tried the cutting oil as mentioned earlier becasue I just had it sitting there. Worked quite well and now they open and close great.
mrbreezeet1
Pretty well what I was trying to say.
My buddy who services sub stations gave me a set of cold klien side cutters. They were still sooooo stiff and could hardly be open. Tried the cutting oil as mentioned earlier because I just had it sitting there. Worked quite well and now they open and close great.
Will have to try it if I get a pair like that.
Good to know. Had never heard this before.
TwoInch
NW INDIANA
thats what i expected was being claimed.
cutting oil or fluid is designed to minimize friction, and heat, same as "ordinary" oils. it cools the work, and the cutting head or drill, and lubricated the two surfaces to prevent tip welding and dulling. Cutting oil or fluid does not in any way cause any sort of cutting action, or enhance metal to metal wear. it is a lubricant, designed to minimize wear and heat, allowing the cutting edge/ surface to what its supposed to do. it also helps flush away chip material, allowing the cutting edge to work cleanly.
cutting fluids are just thin mineral oils or blends of mostly water and light oil. water is a great cutting fluid, but promotes rust. no abrasives whatsoever in them, as it would ruin cutting edges quickly. using WD40 or light weight non detergent motor oil, or 3in1 type oils are normal cutting fluids that are used often.
if you want something with a "cutting action" i would suggest a fine grit lapping compound. and then flush it our fully with brake cleaner after they loosen up some. :rocker:
cheechi
Triad, NC
RemOil or CLP is what I use for all my pliers joints. Mine tend to get dirty as well as stiffen/slow motion from time to time. My daily carry multi tool is just going to get pocket lint/dust 'fuzz' all over it with WD or another oil. CLP is what I have been using for anything that isn't going to sit happy in a toolbox but get used out in the dirt & rain most often.
There's plenty of oils that could help you, and yes if you're trying to 'wear out the stiffness' then not using oil will let the tool's hinge wear faster but I prefer longer life which the 'wear out' method won't give you.
Scotty_B
Wd40 and sand.
OMG! The sand actually works! At least it did for me.
After trying to loosen up a pair of brand new 9" Cannellock diagonal cutters with WD-40 and 3-in-1 oil and not having cutting oil on hand or the patience to soak, I started searching forums and the sand method kept popping up.
My yard has very sandy soil, so I simply stuck the head of the pliers in the sand and started working them. Within 2 minutes, they loosened up. To the point that they were floppy. Gravity did the work.
You don't really need the WD-40. Just wipe them off and continue working them until the gritty feel goes away.
I was pleasantly shocked at how quickly it worked.
