Most use type L
*Actually* I think most use schedule 40 galvanized pipe and threaded fittings.
bigger is not always better.
thicker walls=smaller ID=more flow resistance
also thicker walls=higher costs (~50% more IIRC)
also thicker walls=takes a bit longer to heat up for sweating
take a look here:
http://www.copper.org/publications/pub_list/pdf/copper_tube_handbook.pdf
as long as type M meets your pressure specs, and it should, there is no reason I can think of to go type L. Stick with M.
Isn't pipe diameter standard so a thicker wall copper pipe would have a larger od but the same id? No?
I believe the OD is standard on the different types of copper pipe. Which makes the ID different for the 3 types. This way, copper fittings can be used for all the types of pipe.
I just completed this task this past weekend:
black iron![]()
I was contemplating copper but because of price I opted for the ole and reliable black iron pipe.
This layout provided here was very helpful:
http://www.tptools.com/StaticText/airline-piping-diagram.pdf
My main line is 3/4" inch black pipe and my drop lines are 1/2".
Ordered a regulator, air filter and water separator to install on my two drops.
Next project will be installing a phase panel and running better electric to the garage. Hope to upgrade to a much larger compressor next year. Maybe a Quincy, Eaton or IR.
normally copper water pipe is ID and copper refrigeration pipe is measured OD, thats why a lot of the sizes the fittings are not interchangable.
Actually, you've described the difference between "pipe" and "tube".
Pipe is measured on a nominal OD.
Tube is measured by an actual ID.
The way I learned it (and teach it) is that pipe is based off ID and tube is off OD.
Yup.
Go buy a fitting for 1/2" tubing and you can use it on any 1/2" tube. The wall thickness changes the inside diameter. Go to the Copper.org website and you'll see the difference in the wall thickness between K,L and M.
The fittings not interchangable size to size. But the fitting are all the same. If you are at a plumbing supply house and need a long turn 90* for 1/2" ID copper pipe you ask for a 1/2" 90. Go up the street to the Refrigeration supply house and you need to ask for a 5/8" 90. For some reason one trade does it by ID the other by OD. 3/4" plumbing is the same size as 7/8" ACR, 1" plumbing is the same as 1-1/8"ACR and so on. 3/4" ACR would technically be 5/8" plumbing, but I don't believe that term actually exists.
We must be lazy over here because we just use PVC pipe and never had any problems.
Mike your probably right but if I remember right 3/4" water pipe was interchangeable with 7/8" ACR and that was the only size were the fittings were actually the same below 1".
its been a while since I did any of that work but I do have a 5 gallon bucket of ACR fittings in the barn, I'll have to go out there and check them against plumbing fittings. I just don't think you can put a 5/8" ACR elbow on to a 1/2" plumbing pipe and it will fit............I'll let you know if I'm wrong.....lol
Use black iron pipe, appropriate dope or ptfe tape, and forget about it.
Where do you guys get your black pipe?
