fomocoforrester
- Joined
- Jun 13, 2008
- Messages
- 3,061
What is with the boi in your name^^^? Isn't that how gay guys spell boy?
What if it was? - why is that even worth a comment? - You're not a homophobe are you?
God forbid ....
Brazing is a suitable repair for bolt holes in cylinder heads? Is this meaning like a crack that is on the edge of a bolt hole on the outer cylinder head bolts on something like a small block chevy? I read his question incorrectly as asking if you could repair stripped out threads in an engine block of cylinder heads with brazing. I assume that would not be possible or a good repair?
I have found that the big problem with this process is that you can not see the base weld repair. So you buy a part or a car with a repair such as this that has been blended and then shot with some paint. Then you find out that the guy who did this repair was a son of a jack rabbit after the part fails. If it's done proper it's OK, but if not, it's just plain ****.
Not quite brazing but I saw someone mention silicon bronze with a TIG welder.
I can see the benefits of this. With the tig, you won't put as much heat into the part as you would of with torches.
Thanks for sharing.
mm k, so i have a shop that's 8ft ceilings and like 850 sq ft.
i need to understand ventilation for closed-doors wintertime... brazing or welding..
any direction to point me?
Oh I need to go buy bronze rod now and go empty the tanks on my cutting torch by teaching myself how to braze stuff.
ha ha.. "tuque"
maybe fab a vent hood
What are you using to work the built up bronze back down? This is the part that always seems to really **** when I repair stuff using brazing rod.
I have an old drum type fan. If that's the right word for it. I changed the pulley ratio, so now it ***** like heck. A good thing, because that cement pump was full of acrid smelling grease! I open my garage door about 6 inches for optimal ventilation.
For winter, well, it get's to -30C here. Fahrenheit equivalent for you Southern blooded souls( f'n cold!!) you may die!
I wear a winter jacket and freeze my ears off cause my tuque wont fit under my welding helmet..
My I suggest you use your smaller tipped Oxy-Ace welding torch for practicing on thin stuff first. Your tanks will last you much longer.![]()
Nice jobBrazing saves the day again.
Cast iron concrete pump thing with broken ears.
First step, take some of the **** off of it and wire brushing.
Then grinding all the surfaces clean that need to be rebuilt.In most cases I find that rebuilding from scratch is more durable than trying to braze the broken ear back on again.
With big heavy stuff like this I use my cutting torch for a heat source. I use coated brazing rod to wick the surface first. The flux on them is more aggressive than my fluxer and will stick better to the rough surfaces.
Once the wicking step is complete I switch to a bare rod. In this case 1/8 dia. low fuming bronze. You don't need flux to have bronze stick to bronze and it's cheaper than the coated ones.
Looks awful, no?
The end result, after dressing and machining.Ready for more abuse.
A guys, remember the darn torch stays real hot, even after it's been turned off...
I have some thing I need to braze. But I am concerned about the casting cracking as it cools. I know you can bury it in sand of lime to slow the cooling to prevent the cracking. But I would like to practice first on a piece of scrap first. Do you think and old disc brake rotor would work for this purpose?
Mike
I did a brazing repair on the tool holder for my wood lathe a few weeks ago. I was in a hurry to to get it back up and running so i didnt grind everything smooth when i was finished. I vee'd out the breaks as much as could and I roughed the surfaces up a 24 grit disc to give the bronze some teeth to stick to.
In general, you want as much surface area as practical, clean as possible, and rough it up if possible.
is it true that braze joints conduct heat more efficiently than welded joints? in an application like the interface between exhaust runners and the header flange, it becomes advantageous as the retention of heat increases exhaust velocity. wondering if anyone has had any experience with this, as i'll be building headers from scratch for my swap project in the near future.
I have always read that you couldn't braze/fuse stainless. For example you could never think of making a set of stainless headers with an O/A setup.
Is this incorrect info?
So, pretend you broke an ear off the starter mounting boss on a cast iron SBC (this is a common problem), would this be a good way to make the repair? I'm assuming this could not be done with the engine still in the vehicle. What would the process be to repair the block?
Whats an SBC ?
I started out using wire coat hangers to "braze" exhaust pipes in Dads service station back in the 70's with oxy-ace
wondering if anyone uses this type setup for oxy ace?
I've been using MAP gas (Yellow bottle/burner) to try and braze. I've had mediocre luck, only smaller items I was able to braze.
Should I invest in an Oxy-acetylene setup instead?
After looking at it some more, I see you have no washer on the underside of your bolt. You may want to add one to spread the load.
Just saying.
DAMN! that's pretty,very nice work on that.that's what i love about this board,seein what "real craftsman" can do,i know way to many guy's that would have bought new,i do the same as you and fix what i'm capable of.guy's around me are amazed at what can be done,i always say,what if there wasn't another one to buy? what would you do?Brazing saves the day again.
Looks awful, no?
