Broke my first Snap-on Wrench today
Snapped-off
Indiana
Broke one of the jaws off the open end on a Long pattern Snap-on combo wrench. I don't normally tighten things down with the open end, but clearance issues wouldn't allow for the box end to be used.
I was tightening down a 3/8-16 flange nut with it and the jaw snapped off and flew under my toolbox. I used a Gearwrench to get the last 3/4 of a turn out of the nut.:sad:
Snap-on guy will have one for me next Thursday but I'm a little disappointed, as I just bought this set of wrenches 2 week ago.
Hiball
Missery
It happens, looking at the nut it appears it spread and rounded a edge prior to breaking.
Snapped-off
Indiana
The shiny part on the corner isn't rounded, the plating got scraped off by what was left of the jaw when she broke. It's pretty sharp.
Snapped-off
Indiana
I didn't get to see if the wrench spread or not, I wasn't looking at it as I was tightening it. I would think it would have spread and rounded off the corner before the wrench broke. That particular piece of hardware was just a grade 5 Chinese nut from Fastenal.:headscrat
Hiball
Missery
Dunno.. Could have been defective? Who knows? It happens...
powertrip
Columbus Ohio
If it was a craftsman it would be deemed as junk by the second post and people would have said by snap on next time
powertrip
Columbus Ohio
Nope, just the truth. ***** it broke, and its a nice wrench, but we all know what would be said.
Just warranty it, its a fluke. You probably couldn't do it again if you tried
Snapped-off
Indiana
Im guessing 3ft cheater? :lol:
Sent from somewhere in Tx using Tapatalk
I guess I should have stuck with a 2' pipe:dunno:.
I've tightened down about 1000 of those nuts, which hold down one side of a small rotary screw compressor, so I don't think I'm the problem.
Hopefully it was just a dud. I texted my dealer earlier though and he said he would have one on his truck next week for replacement.
powertrip
Columbus Ohio
Don't the dealers have some sort of test fixture our something on the truck. I recall another member who had a matco wrench that broke in this test on the truck but the snap on wrench didn't break.
Snapped-off
Indiana
To my knowledge, my dealer has nothing of the sort.
DFW-LSX
Houston, TX
Just giving you a hard time, I'm sure it was a fluke like the other guy said.
He might be talking about the torque calibrator thing on the wall like my dealer had? :dunno:
uudfourty
Wow. That really *****, man! See what your truck guy can do to make up for the inconvenience.
bob15
Northeasten, CT
I think you are referring to the Snap On gizmo which would show how the flank drive works when compared to the older, non Flank drive and non-lobular style Bonney wrenches and sockets. Snappy also has the fixture to show how their 4 way wrenches will work better than the competition by turning a nut or bolt 9don't remember which).
As to the original OP, it happens.....
bob
Snapped-off
Indiana
Sarcasm on my part too.:thumbup:
I still can't believe it broke. But stuff does happen. Pretty sure my dealer mentioned he is getting something to measure the accuracy of torque wrenches on the truck, but no calibration. I don't think that is what the guy was talking about though.
It's less of an inconvenience and more I can't believe it broke so easily, so I'm not really bugged by not being able to use it for a week. I only bought the set because I pretty much got it half off brand new.
oldtools
I think this is a heat treatment issue. Heat treatment involves several steps. I think they forgot the step to reduce the brittleness and increase the toughness of the metal (tempering). Heat treatment is done in batch (not individual wrench), so there will be a batch of wrenches out there that are susceptible to fracturing.
redwrench60
East Tennessee
Yup, this is why good tools have warranty. You have a true brand new defective wrench. Had you been using it hard for years and broke it then I'd say abuse but broke right out of the gate.....time for warranty. :thumbup:
Skin
Boston
i very much doubt they forgot a step. They heat the wrenches in giant batches.
I already commented about this in the "best combination wrench" thread but the long snap-ons have no FD+ so i absolutely find them inferior in the open end to Matco or MAC in both contact area and where they engage. Might want to consider one of those brands instead.
Just to hammer the point home. Colored the head of this 19mm bolt, locked it down, used an extra long matco and a long snap-on (essentially the same length) and this is the contact pattern from the open ends. Snap-On on right, Matco (opti-torque) left. The more surface area the less the wrench jaws and bolt corners are stressed. Less chance of bolt rounding and wrench spread/breakage.
oldtools
If it fail after many uses, I can understand it fail due to fatigue. But failing after the first use? Seem like the metal is too brittle. Since heat has distinct step and tempering is usually the last step, there is a good chance they forgot to temper it or did it improperly.
DFW-LSX
Houston, TX
Yeah that's what I meant... I'm slightly retarded... don't know why I said calibrator...
short stack
you were turning the wrench the "wrong" way like the commercial for the show American Restoration.
They must have broken their wrench also. This years commercial they are using the open end wrench the "right way"
Let the flaming begin!
short stack
Mr Ratchet
Broke one of the jaws off the open end on a Long pattern Snap-on combo wrench. I used a Gearwrench to get the last 3/4 of a turn out of the nut.
Those SO wrenches make for some good sling shot material, a little on the expensive side though. Good thing you had those superior GearWrench wrenches to save the day. :lol_hitti
Seriously though, even the best make a bad one now than again. Could have been several things that went wrong. More than likely the new one will work great for years to come.
Pointsnorth
Canada eh
Everything breaks. I work on $8,000,000 helicopters, and you should see how often something breaks. The owners seem to accept high cost items breaking, and life limited parts, as it is just the cost of doing business, with no warranty either.
This is why you paid the money. Your dealer will actually come to your place of work, and put a new wrench directly into your hand no questions asked. That's worth the extra $$$ to me.
6-Speed
Ouch! that must be painful ... what hurt more is you used a Gearwrench to finish off the job. ;)
Snapped-off
Indiana
I could have used a Wright, but I figured what the hell. I just broke a $42 wrench.
Hopefully that is the only Snap-on wrench I break :lol: I don't really like having to warranty things.
Tavy
At least it wasn't the long pattern 15/16 that is strictly used for removing Rockwell rear-ends after the nuts rust-weld themselves to the studs. Put the whole disaster under a garbage packer and you get an emergency room visit for a few broken knuckles.
