64dragnwagon
I thought about it. After doing some research the plastic barrier under the concrete is only good for 5 years. What kind of foam did you use to wrap your posts????
I agree and would highly suggest a barrier between the post and bottom 2x6. I used "blackboard" the stuff they used to use for sheeting on houses. I cut some 4x8 sheets into 4" strips and wrapped the whole base. Here is poor pic of it before pouring. You can buy it already cut into strips at Lowes but it is a lot cheaper to cut the strips yourself.
