Scotty Dont
- Joined
- Feb 22, 2012
- Messages
- 9
Earlier this year my fiancé and I decided now was the time to buy our first house. Being that she's a historian, she wanted a house with "character". I knew what that really meant. It meant she wanted an old house. But with old houses come problems. We looked at a few here in Massachusetts that met her criteria, but we had both agreed that if we were going to get something with some history, I need to at least have a single car garage to turn into a workshop. We finally found a house she absolutely fell in love with and it at least had a garage. Much like I anticipated, the house has it's own set of problems, but so does the garage. So it's time to do some work to restore it back to a condition I deem acceptable. Hope you all enjoy the updates.
The outside of the garage doesn't look to bad at a quick glance. One of the first things you'll notice is that it has a very old window. There's actually three others, but they all had missing panes that had been broken at some point or another. Previous owners put up plywood to cover them and never removed them. I'd like to replace all the windows except the rear one and get some more sunlight in there. The two windows on the left side of the garage face nothing but woods for the next 200 ft. so I'm not overly concerned about people looking through. I also plan to replace the side door with a door I'm working on restoring from the house that is no longer in use.
The other thing you'll probably notice on the outside is that the roof is in pretty rough shape. A lot of the boards on the roof are rotting and I am starting to get a lot of leaks in the garage. The current plywood is also starting to lift up off the boards causing gaps and further leaks. A full strip of the roof, new plywood and shingles and hopefully that takes care of that.
And finally the inside of the garage. The floor has some cracks and is nowhere near flat, but I can live with that. One of the first things I did was build a workbench (seen in the back) and the table to get some surfaces to do the house projects on. One of my biggest issues with the garage is that the ceiling joists are incredibly low. When measured, the bottom of the joist is only about 6'8". On the left, you can see I've already purchased 2x6x14's to raise the joists up. The current ones were nailed in below the top plate. Once the new ones are in, I'll cut the old out. After that comes putting up some plywood on the walls. I'm too scared of doing drywall in this garage for fear of water getting in even after I've replaced the roof. Once the walls are up, I'll be re-doing the electrical with surface conduit. You can see the white door on the right that will be getting restored for the side of the garage.
Other future plans are replacing the garage door with outward swinging carriage doors and doing a foldable table on the wall to replace the current table in the middle to make some room for the motorcycle. I'll try to update the thread as often as I can. Thanks for looking!
