Phatsub
Or is it sufficient to oil tools manually?
.Just get a little applicator bottle to oil them through the tail piece and they'll be fine
Any airtool oil is fine. I don't run an inline oiler because it will contaminate your hoses and maybe your hardlines, depending on where you locate them. Most definately a concern if you plan to paint.
I'm up for suggestions on a good filter/regulator combination unit.
I used to have an inline oiler on one of my guns, i found that i'd fill it and within 2 minutes it was empty. And it took a fair bit of oil too. I now oil my guns whenever i use them, or i chuck in a bunch of oil and let them run at free speed for 5 or so minutes to make sure the oil gets all through the turbine and internals.
Just get a little applicator bottle to oil them through the tail piece and they'll be fine.
Five minutes or seconds? Hopefully the latter, otherwise you're running the oil out that you just added and causing unneeded wear.
On most air tools the lubrication for the air motor does not get communicated with the other areas of the tool (impact mechanism, ratchet mechanism, etc). Lubrication for other areas is usually done through fittings located elsewhere on the tool. A few drops of oil in the inlet of the tool and a few seconds of free speed will thoroughly coat the motor components and you'll be good to go for the day. The difference between the nut / bolt cycles you run and running the tool at free speed is that in most impacts, the motor runs at about 1/10th its free speed while impacting, so very little of a bolt removal or fastening cycle is at free speed. Running the tool at f/s for 5 minutes will just wear out the vanes, cylinder and end plates more quickly. BTW, 800 wheel nut/bolt cycles per day is impressive, what is the application?Minutes. I like to make sure the oil gets through all the mechanism inside. I put in plenty of oil defore doing this. I can't imagine it was any worse that the daily use the gun got, about 800 wheel nut/bolt cycles a day.
Is that (CHUCK IN ), some sort of European technical term??![]()
I use transmission fluid.....a couple of drops every time I plug in the hose....it is just as good as the other stuff.....
But what is more important is to put in a couple of drops before you put it away....a couple of drops...a quick burp to spread it out...then pop it in the drawer....
