Central Air Conditioning, Hide The Ugly Compressor
gahrajmahal
Cincinnati, Ohio
My wife wanted to camoflage the ugly compressor next to the house and found something online. Needless to say it was less than desired and made of plastic. (sorry no photo of that), but we did find out a tall cover would draw your eye to the compressor instead of minimize the appearance. After checking online I found few examples or pictures of how others covered their air conditioning compressor.
After checking the home centers without any inspiration I realized I should be immitating our privacy fence that borders two sides of our property.
I purchased two decorative 4 x 4 ballisters that matched the fence posts. I also bought 20 4" X 4" cedar pickets.Additionally I purchased 8, 2 x 2 fence posts.
The Finished cover.
You can see I had quite a bit of other stuff to avoid like the dryer vent, furnace vent and 220v fusebox.
The assembly was pretty straight forward. I used some Kreg pocket screws to attach the 2 x 2's to the upright posts. The cedar 4 x 4's were spaced using the 2 x 2 as a guide.
I didn't want the wood to be in contact with the ground, so to deter the termites I used these plastic feet they had.
The only fasteners holding the little enclosure near the compressor are 4 screws through the vertical 2 x 2's to the facia of the house. Those 2 x 2's do not come in contact with the ground.
The curve was cut using two screws driven partway into the cedar. I put a thin piece of wood trim between them and bent it in the middle to a pleasing curve. Then I traced it with my pencil and cut the curve with the jig saw.
I measured between the back uprights and cut the front cross braces to the same length. I put a couple of pocket holes in the cross pieces with my Kreg jig making it pretty easy to connect them between the 4 x 4 decorative posts.
I appreciate all the folks who post their projects as I often borrow all or part of the idea around my house. Maybe you can get an idea from mine.
pipsters
USA
Neat idea but too close to the condenser IMO. For proper airflow you're suppose to leave something like 3' on the sides.
Reading thru I can't tell, can it be easily removed for servicing?
furnacewhisperer
I hate that this is my first post, but why are you embarassed of the machine that keeps you comfortable inside? I hope that you took the same consideration when hiding your trash cans. Honestly, I'm not trying to sound derogatory. Rich
premierplayer
Maryland, USA
That looks great. I've got swimming pool equipment and A/C on the back of my place I'd like to hide. You've got me thinking...
Ron Lombardo
New York
... looks very nice ...BUT did you read the Manufactuers recommendations .... need a minimum of 30" on the 3 sides for air flow ... those solid boards are going to burn out the compressor and condenser fan ... also how are you going to pressure wash and clean the coil every year ?
R
er3456df
R
With the gaps in between the boards, 30" may be overkill- but yeah, space em out a lil. 1 foot on each side wouldn't look too bad.
green.bubbly
Lafayette, LA
Neat idea and it turned out nice. As mentioned, you might have a problem with airflow but with the gaps in the boards, you might be ok. You could also leave off the section furthest from the house if need be. The unit would still be hidden from the front and back. Do you plan on painting it the same color as the house? I kinda of like it the way it is. Good contrast.
On a side note, I would do what I could to deflect the dryer vent away for the unit as some lint will get sucked into the coils causing them to eventually clog.
How do you like that Kreg setup? I just ordered a set after eyeing them for several months. First project will be some cabinets.
G
gahrajmahal
Cincinnati, Ohio
Obviously you have not checked out my " what is the best trash can" posting I did last year. I do care how those cans look. Still looking for those new cans by the way.
In the fall I vacuum the leaves, spiderwebs and mouse nests out from the inside. I then lubricate the motor shaft and other sprayable surfaces with WD 40 or similar. Then it gets a heavy vinyl cover. It's about 15 years old now.
Green Bubbly, you are going to LOVE your Kreg setup. I only have the basic set. I bought it for a custom cabinet project and it really made the job easier and better. It is super strong when combined with normal glue up. Be sure and post up your project. I will keep an eye out for it.
Yes I know looking at it it does seem a bit close. But I have to tell you it is more open than the one we purchased initially. I may add a spacer to the house thereby bringing the front out a bit. It will make it intrude into the path a bit more.
Bull
It looks like a very neat job, for sure. Nice choice of materials and careful attention to aesthetics.
I am also concerned about the airflow; the spaces between the boards aren't going to make up for the lack of openness.
Please also consider how the unit will be serviced, as mentioned above. If a tech has to come to your house and fit his own body, plus his manifold set, plus some tools, and find room to bend/kneel/work, even a 30" space begins to feel very constrictive.
The companies that sell the covers don't need to fix the problems that they create, so I wouldn't use their design as a model for what should be done in terms of not harming the unit.
JimL
Indiana
R
Don't use a pressure washer :shocking:
Too close. Don't care if you don't think it is restrictive, it is being that close.
Lugnut64052
Yeah, it's too close and too solid. I'd make it bigger, move the sides about a foot away from the unit, and make it removable. It's a real drag trying to wind yourself into some hole to work on a unit that's in a tight spot.
mitusa
SW Oklahoma
This....and put something down to keep the weeds and grass from growing up around the enclosure. Those units don't take well to deviations from normal. They also work better in shade.
brownbagg
just paint it the same color as house and forget about it, some people got too much time on their hands
BD1
north side
If you want to check for air flow restrictions, take a laser thermo gun and while running check temp at top of condenser fan while running. Remove enclosure and recheck. Just a thought. Looks nice !
Displaced Hokie
Western NC
You guys are busting his balls too much. Note that his machine doesn't have coils all the way around. Just in the front and 1/3 of the sides. I agree, a little more room on the sides would be better, but I think he is OK. It should be able to pull in enough as is.
O.P. - nice job and thanks for sharing!
Bull
My dad was in the plumbing and HVAC trades from the 1950s until he retired a few years ago. I worked with him many times. I know what he would say when called to service such a unit. It's tough to access stuff when it's fenced off!
I don't mean to bust balls. If it works for the OP, then that is what matters.
BD1
north side
O.P. - nice job and thanks for sharing![/QUOTE
The coil should be on 3 sides wrapped around the outside and compressor inside center.. He only took picture of the open side where you can see it.
Jackfre
N CA
Nice work. I too am concerned about your air flows, but...nice work. I guess I would suggest turning the vertical slats about 30-45*, so the wood presents the barriers but there is less resistance to the air flow.
Bronson
Texas panhandle
When I show up hot and tired , to service the unit and see that, I am going to be pissed off. You need more clearance. Restricted airflow will result in more head pressure, higher electric bill, and am charging You by the hour to remove and re-install the decorative fence. Not to bust Your balls, it looks good. Just more work for the Service tech. If the wife is happy......:thumbup:
Ron Lombardo
New York
.... please dont take offence to my comment ... but to achieve the total efficency of a new condensor ... the clearance is very important to keep the temp down and the maintenace cleaning the coils every year and blowing them out is just as important ... maybe some hinges on each post so all 3 sides swing out ... might be a good option.
Ron
Hootbro
Delaware
Whatever floats your boat but I have never driven by a house and said, "look at the hideous A/C compressor". It is just something you expect to see and not think twice about.
jkeyser14
(rural) Maryland
I definitely have. I also can't stand loud compressors. Nothing like sitting outside trying to enjoy the outdoors you can hear is the compressor a couple houses down.
Hootbro
Delaware
What's a two sided fence going to do about the noise? I think the topic is about visual aesthetics and not audible.
BD1
north side
well it sounds like your wife has to go along with the pretty enclosure.:lol_hitti Kidding !
StevePgh
Pittsburgh, PA
I agree with the majority of concerns here, there is not enough ventilation. With the newer 15 SEER (or larger) units, they add lots of coils, making the outdoor units MUCH larger than what you currently have, and much harder to conceal. The amount of free air space needed around my new unit is very clearly spelled out in the manual, and it is > 2' on all sides...
acer66
Western North Carolina
Looks good to me, but I would be also concerned about the airflow.
I was planning to something similar but our HP is like 5' tall
and needs like 2~3' feet clearance around it which would have made it to big for my liking.
I also would not have expected the service technician to remove the fence,
I would have done that before he or she arrived.
I am with the OP on this while I appreciate the function of the AC they have only an inner beauty to me. :)
G
gahrajmahal
Cincinnati, Ohio
Wow, lots of good comments. As I said originally I could not find much on the subject and is the reason I posted. So, OK folks you have convinced me to open it up a little. It is in its current configuration attached with only 4 screws and my HVAC man Tony Weber will have no problem calling me a bonehead if he does not like what I have done. Based on your suggestions I will make some modifications to get some more clearance. I will add a few photos then.
Big-Foot
Midlothian, TX
Nice job! I built one similar only not as nice. I staggered 1x3's on either side of the horizontal boards and had maybe 8" clearance on all sides. Worked fine and the compressor had a south-west exposure. I think it actually worked a little better since it was partially shaded.
Oh btw, this was in Texas where the AC ran literally non-stop for 6-7 months out of the year...
PS on the pressure washing? Not many aluminum fin compressors are going to hold up to that.. I use Simple-Green and a garden hose, then a mist of WD40..
G
gahrajmahal
Cincinnati, Ohio
Acer66, it wasn't a project really. I just wanted to know what are good cans first, then I would like them to look nice. It seems all the manufacturers have gone cheap. I am surprised it has had over 4500 visits. I think most would agree, we will pay a little more for something of quality.
http://www.garagejournal.com/forum/showthread.php?t=91079
GJ member Patent Pending just started a post for garbage can storage. They had a nice cedar unit at Meinards. Check out his thread. He does not have to have adequate clearance ha, ha.
http://www.garagejournal.com/forum/showthread.php?p=2537120#post2537120
G
gahrajmahal
Cincinnati, Ohio
GJ Revisions 9/15/12
So, lets review...
I posted the most awesome air conditioner cover upper Ever!
But I recieved a few helpful "suggestions" as to how it could have been made better.
And, YES, you all were right as usual. So, I still had some cedar pickets left but I had to go out and get some new 2 x 2's to make the front panel wider.
Here is a top view to show what I started with, and you can see the cross braces on the right side and front are up against the compressor housing.
The other good suggestion is to do away with the need to remove screws when servicing the compressor.
First up, remove the 4 screws and remove the "awesome" cover.
Next, dig up the hosta plants because the revised cover will be wider on the right side.
I removed the pickets from the front panel and also removed the two 2 x 2 cross bars from the front. Now I had just the two loose sides with the curved pickets. Now I had two 2 x 2's I could use for the new "House Mount Brackets" I had come up with. This would help to space the cover away from the front of the compressor. It also would give me a place to mount two eye hooks
