Scopes!!!!
D
d_rock
Denver
I looked at those. Problem is you have to use a pc and I have a mac, so i'd have to buy a dedicated computer for it. Plus its only 1 channel and this one i'm looking at is 2 channel.
dsmnickk90
The one you linked is a single channel as well
Vvmvbb
CT
Great price on that Owon. Be interested in how it is.
I'd get the 2 channel even though it's $200 more plus whatever a second probe costs. Looking at two signals at once or triggering one signal off another is totally worth it, or will be.
I assume Flukes are out of reach at $1.5 K plus accessories...
Carguy99
Warrenville IL
I use a pico on my mac....i run boot camp. I run several PC only programs on it...it works fine took a little messing with it but the customer support was wonderful.
I love my mac and I will never go back to a PC.
Stick
Alaska
How much better is pico than a hand held 2 channel?
Apples and oranges. A pico is a hell of a scope, probably one of the best out there, but even on a laptop it's nowhere near as portable or quick to set up as a good handheld scope. It does shine for serious data collection though, with a big enough hard drive, buffer size is pretty much unlimited.
Carguy99
Warrenville IL
I own several scopes. I like the SO vantage and I think it would be the only scope would buy used. Its not a true scope but it does 90% of what I need. If you look they can be had for a bout 200$
Richym76
Have a look for fluke 123 on eBay I got one for £75. It needed a battery which cost £25. I've also got SO vantage it's good as its got a guided function to learn how to use but is not as fast as the fluke so won't see can bus very well.
D
d_rock
Denver
OK, so you want battery and/or 12V operation with flash data storage capable - that's what you call "portable"?
I'm looking for something thats 2 channel, can record data, i can take with on a test drive, and is around 500 bucks.
I'm not interested in the vantage. I've looked at them, but its not for me. I'll check into the fluke.
Stick
Alaska
That's a pretty tall order there for something that isn't ****... If you could live with three of those four, which ones are the priorities?
$500 might buy you a used OTC solarity, but OTC makes **** scopes.
$299 will buy you a Uscope from AES, but it's only one channel.
$800 would buy you a used Vantage Pro from eBay, but you'll have to shop for a while to snag one at that price (usually running "outdated" software, not a big deal).
$250-400 would buy you an original Vantage, but record time is somewhat limited, and it's not a true scope (though it does have a waveform viewer).
What's the reason you're dismissing the Vantage? I've got two of them, along with a Vantage Pro, and honestly they see more daily use than the Pro does (or other scopes I've had access to). For what they are, they're still an awesome piece of equipment once you learn how to use them effectively.
richfinn
Leeds, Yorkshire, England
Anything is portable if you have a decent inverter, those RIGOL scopes are unbeatable for the money. PICO are awesome for vehicle diagnosis and the support is 100%.
Do some research into bandwith/sample rates/storage capacity before you buy anything. That 20mhz scope becomes a 10mhz as soon as you add a channel and the sample rate is not in the same league as a RIGOL/PICO.
PICO now offer a budget version of the automotive scope (here is a link)
http://www.picoauto.com/2ch-starter-kit.html
http://www.autonerdz.com/
http://www.rigolna.com/products/digital-oscilloscopes/ds1000e/
RPH
Michigan Thumb
Sample rate becomes the most important spec in the group. If you don't have a high enough sample rate the displayed signal will be inaccurate.
srmofo
SW ohio
This is what I have, great value for money ($400), works great. Plenty of reviews on Youtube.
http://www.tequipment.net/RigolDS1102E.html
You can go a bit cheaper with the Rigol if you dont need 100Mhz, but for the money I'd go for the extra bandwidth.
Ive got a Rigol as well, except I have the DS1052E . There is actually a Hack out there to convert from 50mhz to 100mhz just by changing the serial number. The firmware is already in place.
Ive still havent needed to do it though
http://www.eevblog.com/2010/03/31/e...l-ds1052e-oscilloscope-into-a-100mhz-ds1102e/
Vvmvbb
CT
You know, it is quite possible that certain blocks of serial numbers get higher bandwidth components (premium ADCs, say). It would be very hard to know if you are hitting the advertised specs at the top end, though it may seem to work fine.
richfinn
So what makes the pico's automotive scope different from this one here?
http://www.picotech.com/entry-level-oscilloscopes.html
Depending on which model of 2000 range or 4000 range (automotive versions are all 4000) scope you get, there are different bandwidths and resolutions.
Everyone I know who has a PICO has opted for an automotive kit as the software is so well thought out and the accessories are innovative and decent quality.
The starter kit deletes quite a lot of the accessories but if your on a tight budget or have accessories from older scopes its a cheap way in.
You can rest assured the automotive version is plenty fast enough for any type of vehicle signal/network and you get free software updates.
richfinn
When he hacked the rigol from 50 to 100 mhz the rise time dropped in half from 6ns to 2.9ns and you could see more detail in the trace he was displaying.
Vvmvbb
CT
Yes, but if, for instance, the ADCs on those 50MHz boards were the slower, less expensive variants, you'd never know it. It would just cause voltage errors for the higher frequencies (distortion). Not saying this is the case, but this would be a fairly ordinary way to cut cost for the 50MHz system.
D
d_rock
Denver
So could a guy get the 2000 series with some basic probes and then upgrade as necessary? are the 2000 series adequate?
CWP1616L
USA
All you have to do is download the user manuals to the various models and you can see what they're capable of.
LINK
PrecisionTools
Victoria, Australia
D
d_rock
Denver
dsmnickk90
So I think I have my search nailed down to these 2 scopes. Will they work for automotive diagnostics and would one be better then the other?
http://www.picotech.com/mixed-signal-oscilloscope.html
http://www.testequipmentdepot.com/o...m?ganclickid=0004c8c226f318a80a2a6587dc00079a
I like the portability of the owen, but I think the picotech is more powerful and I could update it with amp probes and such.....Still a little blurry on the subject.
Can you not use amp probes with the owon?
Stick
Alaska
As I said I my first post, apples and oranges...
You're comparing a handheld scope to a powerful PC based scope. Both are viable for automotive diagnostics, but which one is better depends on what type of diagnostics you're doing. Something like a waveform for an ABS sensor is completely different than looking at primary/secondary ignition patterns.
Quit looking purely at price and specs, and make an honest assessment of what you're going to be using the scope for, and go from there. If you're just getting into scope use you'll have different needs than someone who uses one daily (and knows what they need). As I said earlier, I still use my original Vantage for 90%+ of the scope use I do, and I do some fairly advanced stuff the other 10% of the time.
Somewhere in free parking is a how to on scope use I put together, and there are plenty other posts of mine about scope use there as well. You might want to check them out if this is something you're just getting into, there's lots of good info there.
D
d_rock
Denver
I will check that out. I'm just getting into scopes, but that is the way diagnostics is heading in the auto world. So, would like to get something that I can learn on at home and get proficient with. Flat rate doesn't give you much time to learn things like scopes.
