signcrafter
- Joined
- May 9, 2012
- Messages
- 12,386
Over the years I have probably bought 40-50 tire gauges of various makes and styles. I try to buy "good" ones from the reputable makers, not the 99 cent walmart ones. I usually have a bunch of pencil style ones in the drawer and give those to relatives when they don't have one. In the garage I use a milton bayonet gage/filler, http://www.amazon.com/dp/B001O2ZS50/?tag=atomicindus08-20 and also have a bridgeport gauge made in the USA and looks to be heavy duty, 10-150 PSI, model number 40-403, not sure where I got that from. According to this if you scroll down, http://www.romppais.com/Catalog/Schrader-BridgeportCatAll.pdf , it's now sold under the amflo name as part number 903d, http://www.toolsource.com/truck-tire-pressure-gauge-metal-disp-p-77709.html. Anyway, it seems that no two gauges ever read the same! Is there a way to test these gauges? Maybe use a regulator and a dial pressure gauge coming off an airline and then a schrader valve. This should be able to compare the dial gauge to the tire gauges? Is there a way to adjust these gauges if they are off? Maybe I've just had bad luck buying these things but it sure would be nice to be able to get a couple nice ones to read the same so I could trust them better.
Any advice on tire gauges and why they never seem to read the same as another one? Other than buying another one!
