Recommendations on a portable compressor
theoldwizard1
SE MI
First, "portable" means that one person can pick it up and put it in the trunk of a mid size car or hatchback. It will be used with 1/2" impact for changing tires, filling tires and cleaning. If I can find a used 30+ gallon tank I might plumb that into the garage.
It must run on a 15A 120V circuit.
It must be oil lubed.
The pump should be cast iron or have a cast iron liner.
Durability and cost are important.
Here is what I have found so far
http://www.amazon.com/Makita-MAC2400-Big-Bore-Compressor/dp/B0001Q2VPK/ref=cm_cr_pr_product_top
http://www.amazon.com/DEWALT-D55152-4-Horsepower-4-Gallon-Compressor/dp/B0000CCXTK/ref=sr_1_1?s=power-hand-tools&ie=UTF8&qid=1347373027&sr=1-1&keywords=D55152
http://www.amazon.com/DEWALT-D55153-1-Horsepower-Gallon-Compressor/dp/B00005NMUZ/ref=pd_rhf_se_p_t_4
GarageEnvy
Fresno
First, "potable" means that one person can pick it up and put it in the trunk of a mid size car or hatchback. It will be used with 1/2" impact for changing tires, filling tires and cleaning. If I can find a used 30+ gallon tank I might plumb that into the garage.
Funny I alway thought it meant safe to drink. I don't know of any air compressors (especially oil-lubed) that are safe to drink but I'd second the recommendation for Rol-air for a poRtable compressor.
bobcatdan
Kaukauna,WI
I have been eyeing up a puma. They have them siting next to an IR garage mate, they are identical down to tag on the tank.
T
theoldwizard1
SE MI
BUMP one last time.
Okay roofers and finish carpenters what do you guys use ?
Durability/longevity followed by cost are my top priorities. Seems that too many reviews talk about compressors that leak out of the box or have some part break within the first year.
dandan111
Indiana
My porter cable pancake has been great. It's loud and no oil but it's been a real workhorse for me. it's ran nail guns for guys a few times because their bigger compressors trip breakers.
The dewalts and makitas you listed are awesome. I would go for ether one. If I as doing it over a ir garage mate would be my choice.(I kind of jumped blindly on the porter cable but have no real regrets).
It's a **** shoot on quality and I hope you get a good one out of the box!
carterbeauford
NW PA
I have the older style of that IR and it's been bulletproof. only complaint is the plastic gauges broke off but they seem to have fixed that design flaw with the new one. I've put untold hundreds of hours on it.
6-Speed
I believe the Puma PK5020VP has the added flexibility of operating on either 115V or 230V and it's less expensive.
I have the IR 20-gallon Garage Mate, which I really like, but the Puma comes in a cool blue color.
NedNorton
Colorado, USA
The little Rol-Air has been flawless for all my carpentry crews. It will run 3 framing guns or 2 guys nailing off sheeting or subfloor and you can lift it into the truck a the end of the day.
PCO6
Newmarket, Ontario
I have this little 3 HP / 5 gal. as a portable compressor. It also serves as the backup to my 6.5 HP / 60 gal. compressor. The small one goes on every time I enter my garage and turn on the lights. It's good for light duty bench work when I'm only in the garage for an an hour or so and it saves wear and tear on my main compressor. It now sits on a car wheel dolley and is easy to move outside when needed (also gives me a good place to store one of the 4 dollies). I picked it up on sale for about $100 at Canadian Tire and have been surprised at how well it has worked.
