Socket Driver Organization
nkachur
Manitoba Canada
While I can't find any other threads on this topic. I currently use hansen trays for my regular and impact sockets and am a huge fan.
But as so far have yet to find a really great way to organize all my driver (Screw, Allen, Torx, ect...) Sockets.
I am interested in seeing what ideas all of you have come up with to solve this problem as I currently have have mine tying up my magnetic parts tray.
N
nkachur
Manitoba Canada
Yes I have seen the hansen one... only problem I can see with it is it still leaves me with a bunch of sockets still in my parts tray ;)
Merkava_4
Clovis, CA.
Clips and rails are still the best way, but you've got to have them fastened to something heavy so you can pull the socket off with one hand. The MTS trays are good too but they take up space.
SILVERPLATE
Fort Worth, Texas
Clips and rails here!
All my garage photos: http://silverplate1945.smugmug.com/gallery/565848_4nUo5#37310706_D2rqM
ossaguy
Hi all,
This is my 1st post here.My name is Steve,and I've been a small engine tech for 25 years here in Ca.
I sure enjoy this forum!
I store all of my special-use type sockets in the top compartment of my SO top box.Since it never gets moved,It doesn't need the retension feature of rails/clips.I found that I like the ease of just setting it on a stud.So I used flat pieces of wood cut to fit,then drilled holes in the wood with a drill press,both for the stud part,then the bolt head,so it's flush on the bottom,so it sits flat.That way I can use !/4 inch or 3/8 bolts,to fit the sizes.
If I need to go 1/2 in.,a tight fitting piece of clear fuel line over a 3/8 stud works without having to drill such a big hole.Then painted black,it looks real cistom made.
On the long shaft bit drivers,that need to be stored layed down,I went to a plastic shop and they sell scraps of black or grey PVC plastic for like 25 cents a pound.This stuff carves out nice with a die grinder with a wide-fluted bit,and looks nice.
I'd do a little bit everyday on my lunch break,and that made it not such a huge project.I set it up so its real low in the front,then gets higher towards the rear of the top compartment.This works well if you want to organize a lot of tools that you can't buy pre-made holders for,and tells at a glance what's missing.The only drawback is the time involved.
eschoendorff
Hi all,
That actually sounds pretty cool. Any chance you have pictures of that set-up?
Oh, BTW, welcome to the forum. :beer:
JeepsAreBuilt
The Beautiful NorthWest
I use these for my 1/4 and 3/8 drive sockets.
http://www.lislecorp.com/tool_detail.cfm?detail=710
Works great.. works in shallow tool box drawers. I marked mine where the sizes go.. and boy it helps me find the sockets quick.
For 1/2" I have those pole trays with size labels at the top.
For torx I have a neat blowmolded case with a complete torx set that works great. Allen, and others stay on clip rails, as they dont get used much anyway. My bit sockets fill in gaps in the lisle holders.
danc333
Southern New Jersey
I use Hansen socket holders for my 1/4, 3/8, 1/2 sockets. I have black trays for SAE 6pt, Grey for Metric 6pt. Red for SAE 12pt, Blue for Metric 12pt.I use Ernst socket holders for specialty type (torx, phillips, hex....) I also use MTS 1/4" bit holders for 1/4" bits. You need to have 4" deep drawers for the Hansen trays but you can see at a glance all the sizes and what is missing. I just ordered a set of Hansen Grips to hold my ratchets and extensions. I report on those when I get them.
ossaguy
I plan on buying a digital camera in the next month or so,and will post some pics as I learn how to do it.
Thanks for the welcome!
Moose-LandTran
The Brink of Insanity (England)
Cheap and works well. :thumbup:
Does the job perfectly for me. Don't have to worry about empty/not enough spaces. Also, for job that aren't "toolbox accessible" i can grab the whole rail for times i need a bunch of different sizes.
That said, they're soon going to be riveted to a sheet of aluminium in the box, to store them upright to maximise storage space.
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
I am SERIOUSLY giving thought to getting some of those Socket Lockit's. For my home/non portable box, those cheap socket rails work, although I don't have them mounted to anything (been trying to reorganize the WHOLE shop). But I am trying to get stuff into a portable box, and between the twist and pull, and the magnetic base, I think they may just fit my needs.
I have looked over the years. I like the Lisle, but the magnet wouldn't hold with a light shake (what would happen if you pulled it off the side of your box). The Hansen is good, but requires a tall drawer and with all my tools, something is bound to break those plastic posts (hence getting inexpensive other cabinets). I just kept coming back to one of the really good HF bargains, socket rails.
ossaguy
Do you repair old OSSA motorcycles?
http://en.wikipedia.org/wiki/Ossa_(motorcycle)
I primarily remember them for their trials bikes!
I had a 75 Explorer model,(that is the trials model,but with a trail-type seat and larger fuel tank.) I had to sell it,but sure miss it.There are some pics of it on the Yankee site,and the Yahoo Groups "OSSAmotorcycles."
If you want,see www.rec.us.
click under "Owner's Bikes",then "Steve Johnson's Bikes"
I sure hope to get another one someday.They are such special bikes,I've
been a fan of Spanish bikes pretty much my whole life.I really enjoyed doing all of the work on it,over all the years.
N
nkachur
Manitoba Canada
OSSAGUY, welcome... I too am a junior member and I too can't wait to see some pictures of your set up. Everbody else thanks for the suggestions this is great to be getting so many ideas, Please keep them coming.
Vinko
Los Angeles
I use socket rails and clips.
I use rails too, from Sears. A pain in the ***. My dad uses, in his "roving" tool bag, these large circular metal clips about 8-10" wide, that are like heavy duty key chains to hold a set of sockets. Like 3/8's small shallow metrics, 3/8's large shallow metrics. They're easy to use, but might not be as efficient for an auto mechanic or other tradesmen who's in constant need of access.
TejasBimmer
off I-35, TEXAS!
I have or used in the past the cheap metal clip on socket holders.
Good - cheap, carry to job, ability to add more or less sockets per arm.
Bad - the clips wear out from repeated use and no labels.
Status: Donated to scrap metal yard.
Lisle magnetic trays.
Good - carry to job
Bad - no labels, if you drop all sockets fall out (yep I have done that).
Status: Holds my extra sockets...I really do not use them
Fomloc trays.
yhst-16607655860267_2009_592371
Good: Got a sample for free from a BMW CCA event. Labeled.
Bad: Gets dirty easy, picks up metal shavings, dirt, grease, can transfer to your car or tool chest.
Status: Junk yard.
Since I am setting up my new garage and getting new cabinets, etc. I too have been searching again for better organizers or a better way to organize.
I now will have a mobile tool cart to work on my cars and truck.
So for wrenches and screw drivers, I am looking at the foam rails that Sears has.
For sockets, I am down to Ernst or SocketLock-it...because both are labeled and easy to transport if needed.
Right now I am leaning towards the SocketLock-it version, because it will not let loose the sockets if I drop the set. But I would be wondering how durable it is if dropped from 5-feet a good number of times.
The Ernst versions would be cheaper to replace and easier to modify.
Damn I hate to decisions. ;)
JeepsAreBuilt
Why do you drop your sockets so much ? For those Lisle trays.. I labeled mine, and it worked great ! I used a permanent marker in the middle of the tray.
Moose-LandTran
I'm happy to know you decided not to drill your drawers. :beer:
Yup, i'm calling tomorrow to get a quote on having a couple sheets of aluminium cut to size. :)
X2 that was a depressing thought, those holes in your new box! NOOOO!!!!!
It wouldn't have been a problem, since the rails would stay in the place. I was, however, concerned about having the bottom of the rivets hit the top of the drawer below, and scratching the paint off.
Jared
Victoria B.C
I use a piece of hardwood flooring about 4 inches wide and 3/4 thick and drill holes and glue a peice of dowel vertically, Cheap and seems to work well.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
That looks a lot like what I have in mind when i get a little more time and ambition....
It didn't taker any time at all. All in all about 20 minutes to cut the boards and screw the rails to them. It took longer to get the saw out and clean it back up and put it away.
Uncle Buck
Kansas
Reminds me of how Andy Griffith wired all the crapper seats together so they would snap to attention at latrine inspection in "No Time For Sargents" ..............well at least the old guys on the board might have enough memory left to remember that scene from the old movie! :lol_hitti
wrenchr
I remember and I'm only 31!! My Dad watched that stuff all the time:)
My Favorite is the Great Escape:bounce: I have seen that movie more times than I can count.
a390st
I use clip on rails so that they are easy to carry around if I need to, and they help keep me from losing sockets. If there is an empty spot on the rail, I need to keep looking. They're not great, but I haven't found anything more convenient for when I need to take tools out of the shop.
N
nkachur
Manitoba Canada
Well, I have cheaped out for now. I built my own. It is still a work in progress I think I am going to try my hand at wood burning to label the holes.
and here it is in the box
I will post some final pictures once I get the labeling done.
speed bump
Butte Montana
After thinking about it I store sockets in a number of ways. My 3/8" and 1/4" drive sockets are all on Craftsman rails. My swivel sockets are in the metal box they came in. All of my 1/2" sockets are in a box with the rest of the 1/2" drive stuff. My impact sockets are in the Blow molded cases they came in. The sockets in the car are in a blow molded case. My looses sockets are stacked like cordwood in the back of my case.
If I had to standardize though it would be on Craftsman rails.
Stanger
Alton, IL
Clips and rails.
Other "solutions" such as Hansen waste entirely too much space.
I am in the Hansen camp. The space waste is worth avoiding the hassle of clips and rails for me. I easily find my sockets and can easily remove them from the post, something I can't say for clip rails. Also, it is easy to tell exactly what is missing at the end of the day.
wilbilt
NorCal
I guess that's easy, if you have the space.
Why not? Do you rely on the labels to determine the size?
No difference with rails...if there is an empty clip, something is missing.
