jmlcolorado
I know this isn't garage related, but I know of no other forum then GJ with the expertise I'm looking for.
Heres the rundown. I live in a 1700 sq ft split level home with gas forced air and AC.
I've been in the house for a year now and am really having a hard time keeping the temps equal (or even remotely close to equal) between the upstairs and downstairs.
Both areas are of equal size, only difference is the basement in 1/2 embedded in soils.
If I keep the AC on during the summer at 75*, it is usually 10* cooler in the lower level. I've closed the vents in the ceiling of the lower level with no noticeable change in temps.
The AC struggles to keep the upstairs cool if we have it off for a day. It will run all night to get it back down to temp, which makes the lower level even cooler.
Heating is the same way. The lower level is always cooler. I know some of that is natural for the style of home but I gotta get it to at least be reasonable.
I don't want to keep the vents closed in the basement as that restricts required air flow for the coils. I've had them freeze up a couple times this summer.
I'm a very hands on person and I'm thinking of building some "deflectors" to install inside the supply dusts in the basement. This would allow me to fully open the lower level vents but allow the air to skip over the tops of the registers. I would keep the deflectors "closed" during cooling so the air passes over the top of the registers in the summer, then I could turn the deflector to catch some of the warm air for hearing during the winters. The deflector would be fully adjustable so if the basement (god forbid) was getting too warm during heating, I cold close it a bit more at each register to block a little more air.
The basement ceiling registers are all 10x6" in size. All the upstairs registers are baseboard style. I also think the baseboard registers are restricting the air too much allowing back pressure to be relieved in the lower level. I'd like to change the upstairs registers to 10x6 floor registers too eventually to hopefully help balance the air movement.
Attic insulation is also another problem, which would likely help solve most of this I'm sure, as the insulation is only 3" thick and original to the 1970 build. The exterior of the house has vinyl siding, soffit and fascia installed as well and I'm also thinking the vinyl over the soffit vents is restricting the attic venting. Each of these items will also be inspected and corrected within the next few months.
Attached are a couple photos. One id a crude drawing of what im thinking. The second is my house to show grade. The back yard is the same as the front.
So am I on the right track of thinking here? You think these deflectors would aid me at all?
