What the heck is this thing?
Mickey O
Chicago, IL
Framed picture hanging on a brick wall, bricks are not used in construction as much anymore.
Jay_mc1
South Dakota
I really like the black background and frame on the brick wall. It really adds to the industrial look. Is this hanging in your shop? Where did you get it? Can you make out any writing or phrase on the machine that you might be able to google it?
maddawg308
Front Royal, VA
I'm going to take a guess. Looks like it's a big pipe on the back of a vehicle with both road wheels and railroad wheels, probably used in a mine. I'm gonna guess it's a large volume air handler, guessing that thing on it's back is a giant air pump, and you hook up flexible air "pipe" to the ends and it pumps air through the mine. Might be needed if you are way down deep and you need fresh air.
Just a guess.
green.bubbly
Lafayette, LA
I don't know but the rear railroad guide wheels look way too wide to travel on railroads. No way it would stay on track when crossing roads.
Norcal
Looks like a sprayer to apply AG chemicals in the fields / orchards to me. But there are things there that lead me to doubt it....
Steevo
43.49600, -112.04300
This was my first thought also.
And I agree with green.buddy about the width of the iron wheels.
Wouldn't work on railroad tracks, but we don't know if the scale is smaller and it fits mine tracks, or what.
1948
IL WI border
i was thinking maybe some sort of ground air/power unit from an airport.... hence the no driver, used behind a tug.
Hobbit
Bama
Turn the pictue around. I want to see the other side of the machine.
JamieK
Winston-Salem, NC
We need more clues! What kind of business was it in? What city? Were there other pictures hanging up showing other equipment that give us a clue? Any names or marking anywhere on the photo?
The tire combo looks like it's self propelled, and not a trailer. But no operator controls; maybe remote controlled. The "nozzles" do not look adjustable; looks like they're fixed. Orange color is for something industrial, and not military. Front wheels and tires looks like 1960's-70s. I don't see how the "rail wheels" would operate to guide it on a track.They're way too high. Anything else anyone see?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Those "Wheels" almost look like lifting points to dump it??
William....
\The so called railroad wheels look more like wheels that would drive whatever is in the cylinder. They appear to drop down and are driven off of the rubber tires. At least the front set does. The rear set or the set on the r.h. side appears to be stationary on the portion of the frame they are attached to.
A few years ago while out riding around, my wife and I saw a large piece of equipment being pulled by a tractor through a field. It was picking up dirt and tossing it out of a drum. The equipment was rather a large piece maybe about the size of this. I have no idea what it was or what it would be called, but it was tossing the amounts of dirt rather far and in a rather large quantity. When it was throwing it, the dirt was fine, like it was busted up in the hopper or barrel. I have never seen a piece of equipment like it before. Maybe this is something similar to that. I can't remember even what exactly it looked like, or what it would even be called, other than it had to be a piece of equipment for construction and not for farming. If I remember correctly, they were using it to make a grass waterway in a farmers field.
