Anyone build a hanging tire rack?
DRRummel
Baltimore, Maryland
I have at least four sets of tire and rims I'd like to get off the floor and out of the way. I was thinking of sinking some eye bolts in the wall studs to hang some chains and strong pipe. I will post a drawing later.
I am curious to what others have done and how much weight seemed safe to hang from the walls.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
A search turns up quite a bit of different ones. Check this and scroll through some of the threads http://www.garagejournal.com/forum/search.php?searchid=1828010
Tech Guy
Ontario Canada
Well if you are in Canada, Canadian Tire just put one on sale for about $79.00 CDN. Floor or wall mount and holds four tires
D
DRRummel
Baltimore, Maryland
Old post, but here is an update.
My son helping me mount the rack to the wall.
Spot checking the alignment of the rack.
Lastly, the tray support struts are put in place.
The rack rack is 15 feet long. I have three 4 foot folding sections and one 3 foot section.
E.rodz
st.paul MN.
Built one myself years ago I have posted picts on my garage build . Your rack looks good keep up the good work.
38Chevy454
Cincinnati, OH
How strong is it? It looks like it's bending with only 4 tires, which is probably about 50 lbs a pop.
Looks like you have room for 1000 lbs of wheels/tires.
The bottom is 3/4 inch and the uprights are 1/2 inch galv pipe. Does it flex a bit? Sure, but it is nowhere near any permanent deformation. You could add additional uprights or wall support if it bothers you. You do not have to do my way, just showing an example of how to make one cheap. My total investment is about $70 for the whole thing. Plus fab was easy as threading the pieces together and adding a few large screws.
I have had 14 wheels and tires on it, without any trouble. It is about 8 ft off the ground so no head clearance issues. My garage is for working and is not intended for man-cave or trying to win a decorating contest.
DekeT
USA
Don't tires get a lump when you store them like that or doesn't it matter without the car weight on them?
bullfrog123
SE Idaho
Looks to me to be a real PITA to get tires up there. Down isn't such an issue. I guess in my case I am dealing with pickup and Jeep tires which are considerably heavier than lil car tires.
Steve91T
Huntersville, NC
Just buit this tonight. I had 4 feet of dead space that was perfect for my 2nd set of race wheels/tires. It's stronger than I thought it would be.
Steve91T
Huntersville, NC
Maybe my post came off wrong. I was simply asking because I was about to build a rack myself and was going back and forth between using pipe or wood and I wanted to hear about your thoughts on it now that it was built.
skeletonizer
My car has 20" wheels with 255/45 tires. I only put tires up there twice a year when I change the snows. They are heavy. Once every 6th months is not a PITA in my book
what size of pipe are you using?
If I recall it was 1".
skeletonizer
I suppose they could. I rotate mine a small amount about once a month, just push up on the tread that faces out and they spin a bit. Takes 30about seconds for all 8 at most. I generally do this when I am running my generator for its monthly workout.
