e-tek
Needed to change thr EGR valve on my 06 Dodge Caravan......20 minute job - right?
After removing the exhaust to intake tube I plugged the hole with some blue shop towel - so nothing could fall in. Always thinking ahead.
Of course the bolt that holds the EGR to the block was seized....so I tried some WD40, then PB Blaster....then decided only heat would work, but being too close to plastic parts to use fire, I decided to run the engine to heat it up.....
Insert major SUCKING sound here.....
Nooooo!!!!
Oh well - I wanted to re&re the GD Intake Plenum today anyway....
Yep, there it is....some of it anyways...
After removing some of it with pliers, some with the vacuum and some with the air hose, I hoped for the best and buttoned it back up, finished the EGR swap, then sprayed a can of Carb Medic down the TB to try and get the rest of it through the system. Seems to have worked.
I'm going back to metalwork.....
Nooooo!!!!Oh well - I wanted to re&re the GD Intake Plenum today anyway....
Get it?
