Do I need crowfoot wrenches
ToolGlutton
Washington, DC
Guys, as a weekend warrior, do I need a set of crowfoot? :headscrat
I think I already have most of the tools that I will need, I'm just so addicted to buying tools. :argue:
Moose-LandTran
The Brink of Insanity (England)
They're one of those things that go a long time unused, but the one time you need them, you need them. They're lifesavers in the right situations, often if time isn't an object you can work fine without them, when in a bind they are invaluable.
dxdexter
They are one of those tools that are nice to have when needed, but unless your in the trade, will seldom be used, if ever. Mine have sat idle for 20 years (no exaggeration). That being said: Go for it.:thumbup:
5wndwcpe
Southeastern, PA
I agree with all of the above. As an aside, that's one of those great tools that you can ask for x-mas or birthdays, etc. etc. They're inexpensive, nothing you can't live without right now and when you really need them, you'll be damned glad you have them.
Moose-LandTran
Whatever drive tool desired > Special Stahlwille extension > Crowfoot.
Aforementioned tool:
I'm going to make some of my own like this with some i got in an eBay auction earlier. :)
jay50
Don't cheap out on the crowsfoot; cheap brands will let you down when you are in a tight area. I recommend SO for these. I also have a flarenut set.
TNToy
West Tennessee
I have a full set of 8mm-22mm crowsfeet. I use one probably once a month, wrenching for a living.
If you do anything with A/C or power-steering systems, that's where they're most likely to be needed.
But about 5-6 times a year, I'm working on that one bolt. You know, the one that requires you to pull the motor mounts and rock the motor & ****** back with a giant prybar to access? ... Or, you just break it loose with a crowsfoot. :)
paramudduck
ohio
They are worth their weight in gold. When, you remember you have them, and can find them.
They can really save you a lot of work at times.
billymade
New Mexico
I saw them used on diesel tractor trucks on the air based brake system hoses and couplers; also hydraulic and fuel line/fittings.
demonspeed
Gloucester, Virginia
im a professional tech and I don't own a set, but i wish i did! they can be really useful and its something I'll be buying someday when i'm making more money. I guess it depends what you work on. I'f you're working on old-school small block chevy's you probably don't need a set, but if you work on new stuff with tightly cramped engine bays, they're definitely useful
eschoendorff
Unless that SBC is stuffed into a cramped Corvette engine bay!
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
The shop had a set if/when we needed them. They also had a set of flare nut wrenches that had been cut in half and the ends rounded. Those worked in most situations.
Since I have shop access (works both ways, I leave lots of specialty tools down there for their use), I ONLY bought them for home when I found a deal. If it were an emergency, I would have locally bought the S&K ones.
You will have to look at what all you do at home. Power Steering has been the place I have used them the most. Also figure out if you need more metric, or SAE (old stuff/new stuff, foreign/domestic).
Personal opinion here, Skip the open end ones (job for cheap, cut in half wrenches) and go with Flare nut, in either S&K, Snap~on, or OLDER Mac (the newer ones I saw the quality had gone down on).
bigjon
NSW Australia
Can someone post a pic of a Crowfoot in action. I don't own any and would like to see how there used.
