kyles974
hey guys.... I just learned that you should run high voltage and low voltage away....or not close together because of "power bleed."
I'm going to be running power out to garage. (220v about 140ft)
Also will be running another PVC for alarm wires, overhead door remote wire, etc., etc., in a seperate PVC.
What is the rough distance you would keep these apart? 3ft? 4ft? etc.,
Also, is power bleed an issue where they run into the garage? If so, what would you guys suggest using to enter the garage?
