Using a gas line for air compressor flex line
ws6formula
I have a natural gas flex line. This natural gas flex line is normally used for connecting a natural gas applicance (ie. dryer) to the natural gas outlet.
I am setting up an air compressor in my garage and need to connect the compressor hard line (mounted on the wall) to the compressor outlet. The distance from the compressor to the hard line is approximately 18 inches. I know I should use a flex line between the compressor and the hard line. I have read some posts where guys are using high pressure rubber lines with the proper fittings. I checked at home depot and could not see a 1/2" rubber line with 1/2" NPT fittings. Is it possible to use this natural gas flex line in the air compressor setup? I tend to think the best answer is going to be just get a 1/2" high pressure hose made at my local hose/hydraulics shop.
mtwaterguy
Yeah, you need high pressure hose and fittings. NG flows at a pretty low pressure.
Nealcrenshaw
Cleveland,OH
No. Don't use the the flex line. NG flows at about 1 p.s.i waay to low for an air compressor.I would use either back pipe or rubber compressor hose which is designed for this pressure.
W
ws6formula
Thx for the replies. I will not use the Natural Gas hose. It appears the craftsman hose is 3/8" hose with 1/4" NPT fittings. My compressor has a 1/2" outlet and my fixed line is 1/2" black iron pipe. Would I lose much performance (air pressure/volume) by using 3/8" hose (with 1/4" NPT fittings) for a short distance of 2ft coming out of the compressor ?
Lyaec350
somewhere...
Just go to a farm or hydraulics store (Northern, HF, Fleet Farm, Tractor Supply, etc) and get a hose that is 1/2" ID with 1/2" npt fittings in whatever length you need.
logical
Northern fringe of the Motor City Suburbs
Go to any local place that sells hydraulic stuff to businesses (ask any factory maintenace guy, farmer or excavator where to go) and get something like this if you really want to overkill it:
http://cgi.ebay.com/NEW-SWAGELOK-SS...0715084QQcmdZViewItem?_trksid=p3286.m20.l1116
Or just have them make up a rubber one with high pressure hose.
The place I go to makes whatever you want on the spot. I know you can get reinforced rubber made up with and ends you want that will easily handle 300 psi.
Jared
Victoria B.C
Just go to a commercial truck parts store and get a flex line that goes to the brake chambers on trucks with air brakes, Cheap and there are tones of options for length.
Nealcrenshaw
Cleveland,OH
You have two options!
1.buy a hose with 1/2 npt (which may be hard to find)
2.Buy 2 1/2" to 1/4"npt reducers which may be the cheapest route.
you can get these from MSC,fastenal,Mcmaster-Carr,Grainger,Northen tool or the like.
logical
W
ws6formula
thx for replies - I was able to get a 1/2" Universal Hydraulic Hose with 1/2" NPT fittings made by Apache Hose and Belting (out of Iowa). It turns out the local farm/hardware store carried Hydraulic hoses many sizes and lengths. Local store was the Incredible Country Hardware Store http://www.tscstores.com. Price for hose was $13.99
wilbilt
NorCal
Yeppers. I bought a 24" hose and a swivel fitting for one end at TSC for a grand total of about $15.
Lyaec350
somewhere...
Yea, don't forget that hydraulic hoses like that don't have swivel fittings on the end (usually) and you'll have to buy a straight thru swivel or a 90* or whatever works best in your application.
warrent
Trenton, MI
ws6,
you say from the compressor discharge? Just for what it is worth I would not use standard rubber hose or hydraulic hose. Even though a little expensive, if coming off of the compressor because of the heat you might want to look at a teflon lined hose. Something like one of these:
http://www.velvac.com/pdf/2005 Velvac Product Catalog.pdf
If the link gets messed up search for Velvac P/N 142552.
kbs2244
The semi truck guys use high pressure hose for their brake lines.
Check out a truck parts store.
Major Ramifications
River Ridge, Louisiana
I don't think anyone mentioned the fact that the gas flex line is not made to withstand vibration which would cause fatigue in the metal. Even if it could withstand the pressure, the vibration would eventually get to it and POP goes the weasel.
Toysrfun
Denver
I used a NG line on my compressor for the hot line from head to the tank at 120psi and it’s been in use over a year like this working just fine. Not sure from the wall to tank if it’s ideal unless your compressor is bolted to the floor but just because gas is low pressure doesn’t mean the line isn’t rated much higher. Since there are no rules on air lines one can simply try and see what works best for them. You may be able to find the data sheet on the item chosen and see what kind of pressure testing has been done. A lot of times they will pressurize for 200psi for example at a given amount of time and base the durability on those numbers. It’s obvious nobody wants a gas line failing so they’re likely to be rated much higher. Considering black pipe is often used for compressed air no reason the flex line couldn’t be considered. I think we as people tend to look at things in their simplistic form with disregard to other considerations. At the time I wasn’t sure it would work but now after much time and also the amount of heat generated through the line I’d do it all over again. I’ve had rubber pressure lines fail and frankly I’d rather a flex stainless line over rubber any time I find the need. It would be far more likely to leak at the flange then ever burst.
