Help with stake storage...need ideas!
drb007
WI
My boss has a very long driveway. During the winter months, he drives red and white striped stakes to mark the edges for the plow. During the warm season, he needs to store all those stakes. He asked me today if I knew where he could get a 50 gallon barrel, as he wanted to stick them all in there to store them. Not a bad idea, but before he commits to that, do any of you have a better way to store a large number fo 4 foot stakes?
PAToyota
South Central Pennsylvania, USA
How many stakes? I've seen people screw a piece of 4" PVC pipe to the wall to hold such stakes - either capped on the bottom or just letting the stakes rest on the floor below. Even if he had to use a few segments, it would keep them tucked along the wall better than trying to find room for a 50 gallon drum.
cashishift
Omaha, NE
this
ddawg16
S. California
Yes.....^^^^that^^^^^
If one 4" pipe is not enough....get a few of them...hang them from the ceiling....you could most likely make a nice little bracket to hold them....or drill a hole in one side so that you can get a long screwdriver through it to run a screw up through the other side and into a stud.
D
drb007
WI
I would guess he has about 50 of the fiberglass poles, and I like the PVC idea on those. But he also has those heavy green stake with the blades on the bottom that he uses to brace new trees and such. I don't think the PVC would be good for those.
Jay_mc1
South Dakota
I use the same stakes during the winter and I keep mine in a piece of 4" PVC, if that size is not big enough, try a 6" piece. Most construction or plumbing places should have some pieces laying around that he should be able to get cheep or even free.
BD1
north side
Get short pieces of plastic culvert. Numerous sizes available, like 8'', 10'',12''
diameter.
kbs2244
I would get two heavy dowels, like a snow shovel handles and hang it from some old dog chain above the garage door.
This is normally completely wasted space.
I keep my seasonal stuff like pool vacuum handles up there.
rlitman
Long Island
I used to have the fiberglass style stakes, and they all fit in a piece of 4" PVC pipe.
After just a few months, they'd just about all been stolen.
I ripped a bunch of 5/8" pine into square shafts on the table saw, stapled a piece of reflective tape to the tip, and wrote "Stolen from __my address__ " on each one.
They take up a little more space, but none have gone missing since then.
D
drb007
WI
His entire property is fenced, gated, and guarded by four mean dogs...guessing theft isn't part of his worry.
Delta74
Peachland B.C. Canada
check the car washes. most of the soaps come in 45 or 55 gallon plastic drums, and last time I checked there was no deposit, or very small deposit depending on the supplier ( was a few years ago) and most will let you dumpster dive or charge ya 5 bucks or something for them. ask for the bungs too if you want to seal them, otherwise hacksaw or sawzall or whatever will take the top off in a hurry, or drill a ton of 3/4 inch holes for him.
anyway thats my Idea
