Hi All,
Thought I'd give some personal and professional advice.... I've been in the hydraulic industry for 25 years and in the high performance racing industry for about 6 years. There are a lot of crimpers out there but there is a major difference between two types... one is variable stop and the other is called positive stop. I'll try to outline the differences-
Positive stop, these are the least expensive and 'force' you to use a particular brand of hose.... at least if you want to be covered legally. If you crimp a hose and fitting combination that is not by the same manufacturer (or recommended by the manufacturer) on a machine that is not made by that manufacturer such as parker, areoquip, gates, weatherhead and goodridge then you are not covered by the manufacturers warranty, nor do you have legal recourse if you have a problem... each manufacuturer has a crimp spec that varies and is specific to their brand. So, for example, you should not crimp goodridge hose on an aeroquip positive stop machine (ET1000) because it may not give the correct crimp diameter and the general rule is +/- .006 of an inch. Crimping parker hose and fittings in a parker carrycrimp with the correct dies and pusher plates should cover you if there is a problem... I am pretty sure Parker is that way, I know Aeroquip is, or was, as we used to carry that brand before we switched to a Goodridge. So, if you are looking to save a little bit up front, but be locked in to one particular manufacturer - a positive stop crimper is probably right for you.
Variable stop crimpers have a caliper dial (or digital setting) that allows you to vary the length on the crimp stroke and allows you to hit any crimper specification you may be going for... Variable crimp crimpers are becoming less popular by the manufacturers of the machines because they cannot be repurposed, however, from a consumer point of view, a variable crimper will allow you to use anyones hose and fittings in their machine... but be aware that you should still maintain the same manufacturer for the hose and fittings, as the bite teeth or fitting collar thickness may vary from manufacturer which would require a different crimp dimension to be met. The other nice thing on a variable crimper is that you can do other things with it - I've had other people crimp wire rope and garden hose with theirs... a variable crimper is much more versitile and does not lock you in to one particular brand or style... in fact, you would be able to crimp hydraulic hoses with the right die set with a variable crimper - which you may use for your own personal use or start a side business with.
Some manufacturers will provide proper tooling suggestions for positive stop crimpers that will give you legal recourse if you have a problem, please make sure that your recommendations come directly from a source that have time and pressure tested the results to keep yourself safe from harm or death, and yes, this is a very real scenario. An improperly crimped brake hose, or fuel hose can give tragic results. If you are not sure, ALWAYS do the right thing and make sure, or don't do it.
If it were me, I'd recommend the FT1380 crimper from Aeroquip with the proper dies to crimp what you need. We are not a Aeroquip house anymore, but I LOVE that crimper and it is the best in the industry as far as ease of use, dependability and gives the abiltiy to expand to other projects when needed.
Watch Ebay for an FT1380 crimper or it's predicessor the FT1330 crimper but those are getting a little antiquated since it's going on about 20 year since last produced... We've replace the packing in about 4 of them in the last 5 years which is a pretty good track record.
Hope that helps, be safe and healthy-
Tony
Plumbing Monkey
One of the best deals on the FT1380 crimper is on
www.Aeroquip.cc and PM is now a Goodridge Race house at
www.PlumbingMonkey.com If you have any questions or concerns please message me through this site or contact me through
