elguappo
My washer/dryer is in the garage, and I want to add a utility sink to wash up before coming in the house.
Only problem is, the only drain out there is for the washing machine, and of course the open hole for that is >4' off the ground.
The utility sink would be on the short side of an L while the washer is on the long side.
My question, finally, is can I cut in a T lower on the washer drain to accept a sink drain from 8' away? I should have enough room to slope it properly.
(I would also T off the hot/cold lines to the washer as that is the only water out there)
Thanks
Thanks
