Yes, I have three exposed ~8’ (2-2-4) URD wires between the subpanel and LB. Can someone cite NEC so I have something to show him the URD cannot enter the building? Thanks for the help.
EVERY inspector I have EVER encountered has allowed URD to enter a panel. Even a few feet into a building.Yes, I have three exposed ~8’ (2-2-4) URD wires between the subpanel and LB. Can someone cite NEC so I have something to show him the URD cannot enter the building? Thanks for the help.
Sure it does enter the building partially, but I guess in their opinion, and obviously mine, this is not "interior wiring".
All I can say is to be NEC compliant, USE is to be terminated outside of the structure.
I disagree.All I can say is to be NEC compliant, USE is to be terminated outside of the structure.
I disagree.
If they meant the conductors are not to enter the structure at all they would say so. They would have worded it something like "Not to be used within a structure" or something similar.
Bringing in service entrance conductors or feeders a few feet into a building is NOT "interior wiring".
This is a classic interpretation issue and I interpret it different than you.
I don't own a code book. I just do what the inspector tells me to.Ok, so what is the exact wording. I don't have my book with me.
Check with your inspector, I bet he tells you it's fine.I don't know if it helps, but the two wires are marked as "Alcan W 2 AWG AL XLPE 600W". Thanks for all of the responses.
Please note who I was replying to.Been there and done that with our county electrical inspector and was told USE was not to enter the building.
So sorry. It looked like you were posting in reply.I know who you were replying to, I was just stating my experience. Sheez lighten up.
I don't own a code book. I just do what the inspector tells me to.![]()
What I find interesting about this and the comments following is that sometimes you're quoted as saying this or that is required by code or not required by code. Then u say u don't own a code book and just follow what the inspector tells you to do. So if an inspector told u to do something that's not code how do u know its not and how do u show them without a code book if you just follow what the inspector tells u to do? Seems contradictory to me!
You've also said that you bet an inspector would allow USE inside and check with them even though code does not allow it. You even argued with the code but admitted that u don't have a code book to check and see what it says. Then pattenp posted the code and u still insisted that the OPs inspector might still allow it. This seems inconsistent. We should either follow code all the time or not. And I've noticed inspectors don't follow code all the time either which is annoying!
IMO this IS NOT a black and white case of code legal or not.
