Looking for high rise 4 post lift
Boundertom
I am looking for a 4 post lift that will go high enough to park an 8' high truck under. The usual vehicle on the lift (for storage) will be a 5,000 lb Chrysler Imperial. The only lift I have found which goes high enough is the Bendpak HD-7PXW. Looks like a good lift and will serve the purpose, but it is a 7,000 lb capacity. I would also like to be able to lift my F-350 for servicing. The F-350 is about 8,000 lbs, so that won't work. Actually, I did find some lifts that would stack full size buses, but at $40k, those are a bit beyond my means! Any tips will be appreciated!
Tom, in AZ
vwracerguy
try Gregsmithequipment.com
they have always done me right and might have what your looking for
sublimate
Colorado
Your best bet might be to get a 7' lift (there are a few out there) and put it up on 1 foot blocks (suitably strong and stable, of course). You may need longer ramps to get up the extra 1 foot when the lift is down at it's lowest point lowest point.
Boundertom
That isn't a bad idea. I will give that some thought. Thanks!
Tom
