OccupantRJ
I had bought a HF gravity fed paint gun a couple years ago to paint some of my flooded shop equipment as time would allow me, to refurbish some of it. Instead, I got it out last weekend and went at a home painting project in the works, painting 38 cabinet doors for my kitchen remodel. the gun worked better than I anticipated, so I decided to make a parking and refill stand for it.
3 inch pipe was sliced into short sections to make the rings, 3/32" X 3" steel strip was used for the base, and some 1018 steel, 1/4 X 1/2 was used for the structure, as this is what I had laying around. The steel rings were chucked in the lathe to receive a heavy chamfer where the paint cup and strainer would sit.
The milling machine was used with a 3/4" end mill to radius for the handle rest notch, then the angles were bent into the plate to match the vertical post and the handle angle on the gun. Mounting holes were also drilled into the base plate. The metal was cut on a vertical bandsaw, and bending was done using my shop built press brake attachment for the hydraulic press, presented in this link.
http://www.garagejournal.com/forum/showthread.php?t=64510 A beadblasting, along with some of my sail blue paint finished things off. Sure, I could have bought one for around $20, but what fun would THAT be? (see my sig)
